Go to Post The only thing I am learning from this thread is the difference between who is arrogant enough to objectify their own interpretations and who is wise enough to question their own interpretations. - Michael Corsetto [more]
Unread 07-02-2015, 13:34
gappleto97 gappleto97 is offline
FRC #3617
gappleto97 is an unknown quantity at this point
The RoboRIO is suddenly not accepting/running code
We get the following log when trying to build code:
Buildfile: C:\Users\Programmer\workspace\Robot-Code\build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory C:\Users\Programmer\workspace\Robot-Code\build
   [delete] Deleting directory C:\Users\Programmer\workspace\Robot-Code\dist
compile:
    [mkdir] Created dir: C:\Users\Programmer\workspace\Robot-Code\build
     [echo] [athena-compile] Compiling src with classpath=C:\Users\Programmer/wpilib/java/current/lib/WPILib.jar:C:\Users\Programmer/wpilib/java/current/lib/NetworkTables.jar to build
    [javac] Compiling 8 source files to C:\Users\Programmer\workspace\Robot-Code\build
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: C:\Users\Programmer\workspace\Robot-Code\dist
    [mkdir] Created dir: C:\Users\Programmer\workspace\Robot-Code\build\jars
     [echo] [athena-jar] Copying jars from C:\Users\Programmer/wpilib/java/current/lib/WPILib.jar:C:\Users\Programmer/wpilib/java/current/lib/NetworkTables.jar to build/jars.
     [copy] Copying 2 files to C:\Users\Programmer\workspace\Robot-Code\build\jars
      [jar] Building jar: C:\Users\Programmer\workspace\Robot-Code\dist\FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-3617.local
     [echo] roboRIO found via mDNS
dependencies:
     [echo] roboRIO image version validated
     [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only
  [sshexec] Connecting to roboRIO-3617.local:22
  [sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
     [echo] [athena-deploy] Copying code over.
      [scp] Connecting to roboRIO-3617.local:22
      [scp] done.
  [sshexec] cmd : killall netconsole-host
  [sshexec] killall: netconsole-host: no process killed
  [sshexec] Remote command failed with exit status 1
      [scp] done.
      [scp] done.
     [echo] [athena-deploy] Starting program.
  [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
  [sshexec] start-stop-daemon: warning: killing process 3031: No such process
BUILD SUCCESSFUL
Total time: 7 seconds
This log has not changed despite reimaging the RoboRIO. We're getting desperate here. Any ideas?
Unread 07-02-2015, 13:42
Re: The RoboRIO is suddenly not accepting/running code
The code is deploying fine, the problem is likely that your code is crashing. Do you get any message on the Driver Station messages window or in rioLog after deploying?
Unread 07-02-2015, 13:57
FRC #3617
We also have tried it with the sample code, and with known working code. The RIOLog says
ERROR Unhandled exception instantiating robot edu.cold.logic.Robot java.lang.ExceptionInInitializerError at [java.lang.Class.forName0(Native Method), java.lang.Class.forName(Class.java:259), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:197)]
Unread 07-02-2015, 15:15
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
There should probably be more lines after that which will tell you what the real error is.
Unread 07-02-2015, 16:43
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
There isn't. It's weird but if you get an error in one of your constructors (e.g. a subsystem constructor) it throws this error. Could you post your code here?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 09-02-2015, 22:31
Zalmay's Avatar
Zalmay Zalmay is offline
FRC #4528
Zalmay is an unknown quantity at this point
My team is also having the same issues with the RoboRio and I was wondering how you solved it, assuming that you have. If you have I would appreciate some advice on how you did so and what the problem ended up being. Thanks in advance.
