Go to Post Where can I buy the awesomeness that you used on that? Do they sell it at andymark? - HansJ [more]
Unread 07-02-2015, 13:59
Zalmay's Avatar
Zalmay Zalmay is offline
FRC #4528
Zalmay is an unknown quantity at this point
Need help programming double solenoids!
I am a member of team 4528, the Automatons. I need help figuring out why my pneumatics code for double solenoids won't work.
package org.usfirst.frc.team4528.robot;
import edu.wpi.first.wpilibj.Compressor;		//Pneumatics
import edu.wpi.first.wpilibj.Joystick;			//DriveTrain
import edu.wpi.first.wpilibj.RobotDrive;		//DriveTrain
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.DoubleSolenoid;	        //Pneumatics
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;			//Motors
public class Robot15 extends SampleRobot
	Victor frontLeft;
	Victor rearLeft;
	Victor frontRight;
	Victor rearRight;
	Victor pully;
	RobotDrive myRobot;
	XBoxJoystick gamestick;
	DoubleSolenoid pistonArm;
	Compressor compressor;
	public void Robot()
		frontLeft = new Victor(1);	//Set to appropriate PWM port
		rearLeft = new Victor(2);	//Set to appropriate PWM port
		frontRight = new Victor(3);	//Set to appropriate PWM port
		rearRight = new Victor(4);	//Set to appropriate PWM port
		pully = new Victor(5);		//Set to appropriate PWM port
		pistonArm = new DoubleSolenoid(7, 6);
		compressor = new Compressor();	//Set to null
		gamestick = new XBoxJoystick(0);	//Set to appropriate victors
		myRobot = new RobotDrive(frontLeft, rearLeft, frontRight, rearRight);
	public void useElavator()
		if(gamestick.getRightZ() > 0)
			pully.set(gamestick.getRightZ());	//Sets value of trigger to speed of motor
		else if(gamestick.getLeftZ() > 0)
			pully.set(-gamestick.getLeftZ());	//Sets value of trigger to speed of motor
		else
			pully.set(0.0);				//Doesn't run if trigger not pressed
	public void moveArm()
		compressor.start();
		compressor.setClosedLoopControl(true);	//Lets PCM handle the automatic turning on and off of compressor once pressure hits 120 psi
		if(gamestick.getAButton() == true)
			pistonArm.set(DoubleSolenoid.Value.kForward);	//Pushes piston whenever 'A' button is pressed
			System.out.println("'A' button is pressed: Piston moves forward");
		else if(gamestick.getBButton() == true)
			pistonArm.set(DoubleSolenoid.Value.kReverse); //Reverses piston  whenever 'B' button is pressed
			System.out.println("'B' button is pressed: Piston moves backward");
		else
			pistonArm.set(DoubleSolenoid.Value.kOff);		//Disables piston
	public void operatorControl()
		myRobot.setSafetyEnabled(false);
		while(isOperatorControl() && isEnabled())
			//squaredInputs help to lower speed value of analog sticks at lower values
			myRobot.tankDrive(gamestick.getLeftY(), gamestick.getRightY(), true);
			Timer.delay(0.005);
			useElavator();
			Timer.delay(0.005);
			moveArm();
Unread 07-02-2015, 15:09
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Need help programming double solenoids!
What CAN ID is the pneumatics control module on?
It needs to be oset to zero for the constructor you're calling yo work.
http://team2168.org/javadoc/edu/wpi/...enoid-int-int-
If you have it on a different ID, you should use
http://team2168.org/javadoc/edu/wpi/...d-int-int-int-
Do you see the LEDs on the PCM change when you press the joystick buttons?
For more info on the PCM, look here: http://controls.team2168.org
http://team2168.org
Unread 07-02-2015, 20:55
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
otherguy is right on all counts.
Though we should mention where the official documentation is
http://wpilib.screenstepslive.com/s/...ribution-panel
...and...
http://wpilib.screenstepslive.com/s/...control-module
