Go to Post Please search before you post (it's fun and free!) - Billfred [more]
  #46   Spotlight this post!
Unread 07-02-2015, 14:59
Re: LIDAR Sensor has arrived!
Originally Posted by muvicado View Post
Maybe I'm missing something. The LIDAR's slave address must be configurable somehow.
The pre-release descriptions all talk vaguely about being able to control multiple devices on the I2C bus, but none of the available documentation I've been able to find mentions anything about configuring the slave address.
  #47   Spotlight this post!
Unread 07-02-2015, 15:41
muvicado muvicado is offline
FRC #0135
muvicado is an unknown quantity at this point
Do you know if more than one LIDAR-Lite can be connected via CAN through the MXP's can bus?
The LIDAR-Lite appears to have a fixed slave address - 0xC4.
LIDAR-Lite Spec
Why would they not make it configurable? Seems like that would prevent one from being able to use multiple LIDAR-Lites on the same I2C bus.
Okay, I discovered the slave address can't be changed on the current version of LIDAR_Lite. From PulsedLight's forum, I learned a work-around for this. Using a DIO pin for each LIDAR, connect pin 2 of connector J1 on the LIDAR to a dedicated DIO pin on the RIO, using this as a "device select" line. Just before and just after the Write/Read sequence to each LIDAR, set teh LIDAR's device select high and low, respectively. We will try this out, using a C++ application.
  #48   Spotlight this post!
Unread 09-02-2015, 11:50
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
I'm having trouble getting this working via C++ -- created a separate post on the topic -- any thoughts?
http://www.chiefdelphi.com/forums/sh...d.php?t=134212
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
  #49   Spotlight this post!
Unread 22-02-2015, 19:10
FlyOldPlanes FlyOldPlanes is offline
FRC #1592
FlyOldPlanes is an unknown quantity at this point
Here is what we did with java:
The big thing was we had to add a pull up resistor on the clock pin.
http://www.chiefdelphi.com/forums/sh...ighlight=lidar
Lennie
