Go to Post I'm sure FIRST did the math. They always do the math. Just not math humans use. It was probably given to them from NASA from the aliens so we'd quit predicting the divisions before they release it. - Koko Ed [more]
Unread 07-02-2015, 14:56
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Victor 888 Controller
We have two victor 888's hooked up to two motors in a gearbox. The motors are working fine, but the LED indicator is not doing what the manual says it is supposed to. When we run the motors forward and backward, the light goes off instead of turning green or red. They also don't flash in sink when the robot is disabled. Has anybody else experienced this?
Unread 07-02-2015, 15:03
Re: Victor 888 Controller
They need to be calibrated to the joystick you are using.
They just aren't going full speed.
See page 2 for the procedure.
Unread 07-02-2015, 15:08
FRC #5005
The person doing our programming is certain that he has calibrated them. Could anything else be causing this?
Unread 07-02-2015, 15:31
FRC #5005
Ok we got it working, thank you for your help!
The Victors only light up at neutral and at full speed.
Other speed controller models have a different system and blink faster as they go faster until they go solid at full speed.
If you are still using the identical joystick that was used to calibrate the Victor, then it might need to be done again.
