Go to Post FIRSTies always get Two Xmases! - [more]
Unread 07-02-2015, 17:31
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
Re: motor programming
It sounds like you need to use a state machine, there's several tutorials at This LabVIEW Tutorial Site, it sounds like you would have a forward, second motor, and reverse (or more descriptive for what those motors do). A state machine can be implemented in either periodic tasks or in Teleop (only caveat is that when done in Teleop, one either needs to insert a while loop that only runs once (constant on the terminal), or use the main program while loop and pass the data in and out of Teleop.
