Go to Post Now please, go have some meaningful discussions that will inspire us all. - Ken Leung [more]
Unread 07-02-2015, 18:35
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
Re: Using wood on a robot
Team 51, the Riot Crew, built a pretty mean robot completely of wood last year.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 07-02-2015, 18:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're about half and half this year, wood and aluminum. One of my favorite pastimes during robot season, is trying to get a chunk of 2x4 into the robot somewhere. This year I succeeded again. Yay.
Unread 07-02-2015, 18:45
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Just make sure you follow Rule W72 and use wood treated with fire retardant chemicals. We don't want an electrical spark causing a fire on the field.
Just kidding.
Unread 07-02-2015, 20:33
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Neat trick! I don't recall there being any wooden motors, nor have I noticed many pneumatic actuators made of wood. Even pinewood derby cars have steel axles, polystyrene wheels and (usually) lead weights.
Seriously, no reason at all not to use wood for the functions for which it is suitable. Now if I could just convince our head coach - excepting our rookie year, he has vetoed every proposed use of cellulose on the competition robot.
Unread 07-02-2015, 20:41
MarcoVi MarcoVi is offline
FRC #2283 (Panteras)
Team Role: Scout
MarcoVi is an unknown quantity at this point
It's not that there's a rule against it. It's just that wood is typically a weaker material than aluminum, and on a game more based on contact, they can suffer.
I think they will really shine this year though, considering that robot-on-robot contact will be almost non-existant.
Good luck on this final build-week!!!
Unread 08-02-2015, 01:07
EricH EricH is online now
Let's just say that I've seen quite a few wood bots out there, and haven't heard of too many of them getting damaged as much as you seem to think they would be. For instance, 4183 ran over a prototype frame with an older car. The car suffered a flat tire on the second attempt. I think the frame is still going.
Please don't make such a blanket statement. Wood can be nearly as strong as aluminum; it depends on the application and grade of wood in question. Gimme some baltic birch ply of appropriate grade, a laser cutter, and some proper adhesive, and I could probably build a frame that can take a beating that an aluminum bot would show battle scars from, too. I could also build an aluminum frame that would fall apart or break the first time another robot hit it. (6061 T0 aluminum, anybody?)
Also, different materials are strong in different ways. This particular fact is what makes materials engineering so interesting of a field should you choose to go deeper into that statement and enjoy the research.
Unread 07-02-2015, 20:49
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Pretty sure FRC 51 is Wings of Fire, and FRC 58 is the Riot Crew.
I think wood gets the same restrictions as anything else: use it where it's appropriate. Know the strengths and weaknesses of the material.
Wood tends to be a pretty good compositing material-- sandwich it between two metal sheets for a lighter-weight but thicker alternative to metal plates. There are all sorts of uses I can think of for wood.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 08-02-2015, 01:57
Andrew Lawrence
Posts: n/a
Team 51 is the Wings of Fire. Team 58 is the Riot Crew.
Unread 08-02-2015, 09:11
scaryone's Avatar
scaryone scaryone is offline
FRC #0058 (The Riot Crew)
scaryone will become famous soon enough
Its Team 58 but thanks for the compliment. Look for a lot of wood this year as well.
Unread 08-02-2015, 09:20
scaryone's Avatar
Use Baltic Birch plywood. Advantages often outweigh aluminum. Wood will bend without breaking and bounce back into shape (of course to a limit). We often feel that wood weight vs strength makes birch superior. Also, so darn easy to work with. Over 80 matches last year (and some really rough ones) and the bot looks like it did on bag and tag day.
Unread 08-02-2015, 09:51
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Riot crew always builds such sweet (wooden) machines.
___________________
- Tennyson, Ulysses
