Go to Post From what I've seen in FIRST, teams that copy generally always learn something from it, and if they don't, the copy they produce is of much lower quality than the original. - TheOtherGuy [more]
Unread 02-06-2015, 07:55 PM
FleventyFive FleventyFive is offline
FRC #4118
FleventyFive is on a distinguished road
Program crashing when grabbing USB Camera frame + misc comm issues
I'm trying to work on vision code or at least displaying a camera feed on the dashboard, but the program crashes on the function where I set the camera server frame. I know about the StartAutomaticCapture function but I'm trying to actually have each frame in memory so I can threshold it or w/e. I have a command that executes this every update time (5 ms or whatever the default is).
	cam->GetImage(NIframe);
	CameraServer::GetInstance()->SetImage( NIframe );
	Wait(0.1);
This causes the program to crash. The DriverStation says there is no RobotCode until I redeploy it/restart the roborio. The debugger says it is on this line (66) of wpilib's CameraServer.cpp.
    while (start < dataSize - 1) {
      if (data[start] == 0xFF && data[start + 1] == 0xD8) break;
      else start++;
The header file for this command declares these variables
	USBCamera *cam;
	Threshold *thresh;
	ColorImage *frame;
	Image *NIframe;
	BinaryImage *binaryFrame;
It's been pretty frustrating trying to figure this out. Any ideas? I'm not sure if I'm making an obvious mistake or this is actually an odd issue. Also, even without any vission stuff happening we seem to have communication drops for a second every once in a while, but this might just be low battery. Is my program perhaps too big? It is CommandBassed with like 10 command and 3 subsystems and a few PID loops. Thanks!
Unread 02-07-2015, 06:20 PM
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Re: Program crashing when grabbing USB Camera frame + misc comm issues
I'm a bit perplexed why you're trying to 'set' the camera frame at all. If you're looking to do image analysis, you'll want to 'get' the frame from the camera and then do analysis on it.
In the case of wanting it on the smartdashboard - that can be accomplished by adding the video pane to the smartdashboard directly. I think this is in the menus or it is a right-click on the dashboard to add it. No programming necessary.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 02-07-2015, 06:25 PM
bob
This is not true for the USB camera. You need code to forward the image.
OP, you should check to make sure that you are actually getting a non-null image of non-zero size back from your call to GetImage. If you are calling GetImage every 20ms that's 50FPS which the camera can't provide, I haven't played with this enough to know if that's why your having an issue, but it would be my first suspicion.
Unread 02-07-2015, 06:48 PM
FRC #4118
This was my guess as well. How to I check if it is non-null? The WPILIB image class has no public functions or attributes at all. It's very confusing... like how can I convert between the Image returned from the USBcamera and the other wpilib image classes like ColorImage (which have public functions like thresholding or w/e)? The AxisCamera class has functions to return these other types of images, but not the USBcamera. Thanks for the help.
Unread 02-07-2015, 06:59 PM
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
I know that I have to power cycle the roboRIO when I upload code it can find the camera sometimes.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
