#16
Re: Can't connect to D-Link
From that ipconfig it appears that your wireless is Disabled (or non-existent) since there is no entry for it.
It also has an odd IP address (10.0.2.15) for the Ethernet port. Is the laptop Ethernet port connected to a building network or to the robot's DLink? To connect via Ethernet to the DLink try this:
#17
Mr. Anderson, we have succeed...partially. We were using a Virtual Machine, now changed a computer and it worked. The problem we currently have is that we can deploy the code into the robot, but unless it is connected with the cable the "Communications" and the "Robot Code" are lit red.
#18
Is your computer still set to that unexpected 10.0.2.15 IP address, or is it now configured properly for DHCP?
Can you ping roboRIO-5750.local? Do you get the web interface when you point a browser at http://roboRIO-5750.local? |
