Go to Post The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning... - s_forbes [more]
Unread 07-02-2015, 21:14
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: [C++] Use CAN Talons in RobotDrive
Originally Posted by 1452-Leo View Post
I tried turning the safeties off already and it didn't work, but I'll try the disabled loop tomorrow and get back. I agree that dummy PWMs is a bad solution, but we're going all CAN this year so it shouldn't really affect anything, and we will probably revert to it if your solution doesn't work because we've spent too long trying to get this to work. Thanks for the help though!
Turning off the safeties in the CANTalons is not sufficient. They are already off (they default off). The problem is RobotDrive has it's own safety enable.
Anyway if you are still seeing the EXACT symptom of "...Motor Safety Timeout..." errors in the DS then you need to remedy it. Even with the PWM workaround (eek) you're still generating errors in your DS log. That's going to prevent your drive team from seeing other reported errors (because they will get used to seeing errors in that area of the DS".
m_robotDrive->SetSafetyEnabled(false); will absolutely prevent MS errors. If you are still seeing them then something is very wrong, and it will likely be a problem throughout the season.
