Go to Post I am definitely as much a student as any one of the kids on the team. - Hieb [more]
Unread 07-02-2015, 22:37
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: Brand New Electrical People Make this
Originally Posted by Cecil View Post
Heat shrink or electrical tape are the easiest ways to insulate them. I think the heat shrink that came in the kit is too small to go over those terminals, but there was plenty of electrical tape supplied.
I also do agree with this to some extent. They can work loose over time, so if you stick with them, make absolutely sure they are as tight as you can get. If you decide to switch to the crimp ones that came in the kit, they have to be crimped right or they can fall off. We use this crimper and haven't had a problem. We crimp in two places and don't worry about it. If you don't have a crimper that will work on that size terminal, I have heard of teams using a vise to crush them down. Whatever you do, do a pull test on them to make sure they are absolutely secure and won't fall apart during the match.
Alright. We have some large heatshrink so we will use this (our goal was to use zero electric tape because last year everything was held in with electric tape and it fell apart completely) as for crimping we have no problem, the "help desk" or it guys at our school use our room sometimes for its tools but they also allow use to us their tools which includes all sorts of industrial grade crimpers. Thanks for the help.
Unread 07-02-2015, 22:48
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by Sperkowsky View Post
Do we have to take it off durring the match? OR can we just not use it during the match. Its the led ir reciever and we planned on using it before the match to put the alliance color on. It has built in memory so it remembers what color it was on last. Thanks
I'm really not sure. It might vary from inspector to inspector or event to event, but I'd bet you could get away with covering the receiver during matches.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 07-02-2015, 23:07
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
I'm not 100% sure but it appears your PWM connectors are plugged in backwards. If I recall correctly the black wire of each connector should be toward the outside of the RoboRIO.
Nice wire routing work though at times you may regret using all of those tie-wraps when changes need to be made.
You can help wire our team's robot anytime.
Unread 07-02-2015, 23:27
Sperkowsky's Avatar
Im not sure if its the right way but whatever its an easy fix. Thanks
Unread 08-02-2015, 00:30
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
It looks nice for your first ever electrical panel! My only recommendation, and this is purely aesthetic, would be to look into the possibility of using zip-ties to secure the wires leading from the PDB to the Talons down to the board in a similar fashion to how your PWM cables are fashioned. It's a minor thing that could help clean up the appearance of the board just that little bit extra without making the panel unserviceable.
One minor thing that would make it easier to use at competitions is the orientation of your router. I'm not quite sure how much clearance you have between your main disconnect (power switch) and your open ethernet ports. Since you have to tether to your robot at competition when you're not on the field, I would double check that you have enough room to comfortably plug an ethernet cable into the currently unused ports. If not, you may want to see if you have enough length on your cables to flip the router around 180* to make tethering to the robot easier.
Overall though I think it's a very nice job! A lot of robots show up to competition with what my team has dubbed "spaghetti monster" wiring that kind of goes all over the place. This wiring is well organized into little "highways" of sorts such that all your wires are routed along one main loop between components, and it really make the wiring look a lot cleaner than it would otherwise!
Good luck at the competition!
It's not done until it's overdone!
Unread 08-02-2015, 09:56
Sperkowsky's Avatar
Thanks I will zip tie the talon wires as much as possible. As for the router there's really no way to put it anywhere else but I tested it and everything can comfortably connect to it. Thanks again
Unread 08-02-2015, 14:26
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
I think 254 would be too embarrassed to take in our robot even as their 2,000th foster bot. However we are still quite proud of it....Now lets hope we finish it in time. Again all joking aside Ill bend a piece of lexan in the same shape tomorrow and put in over everything. Then Ill hinge it so its still easy to access. I think that will add enough protection while still not being too intrusive. Thanks for the input.
I believe your main breaker needs to be accessible without having to remove or open any hinged cover. Its not clear if this is what you meant or not. You can put a hole in the Lexan cover that will allow a hand/finger to get in to push the main breaker button. (just make sure the hole is small enough to not a allow a tote or bin through it :-) )
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 08-02-2015, 14:45
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
A couple notes I see:
Radio: good location. Can't quite tell from photo whether the other Ethernet ports on the radio are accessible -- you should set it up so that you can tether your driver station to the radio, not to the roboRIO. It's cheaper/easier to replace the radio when someone trips over your tether.
Use electrical tape to fasten the barrel connector into the radio. They occasionally come out.
Most teams use Velcro to attach the radio to the board -- easier to remove the radio and take it to the programming station at competitions. We mount ours with the white side to the robot. Use a sharpie and write your team number and 2015 on the radio and your roboRIO. Do not cover up the label on the radio that indicates the model and version number -- needs to be visible for inspection purposes.
If you make a short cat5/6 cable, be sure you're using stranded and not solid wire (more reliable). Personally I'd buy one rather than making it.
You'll want your vertical board fairly rigid if you're going to have the navX installed in that location.
Be sure you have good tie down locations for the load side wiring on your speed controllers -- not a lot of room in the photo you're showing. You'll want to both make those wires into bundles and have them tied down within a couple inches of the controller -- the screw terminals tend to work themselves loose.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 08-02-2015, 15:28
The NavX doesn't want to be in that orientation. It's programmed to assume it's mounted flat.
Unread 08-02-2015, 17:31
Sperkowsky's Avatar
We aren't using it anyway haha we just didn't bother taking it off.
Unread 08-02-2015, 17:32
Sperkowsky's Avatar
Thanks we were out of Velcro and did what we could the other side an be taken off pretty quickly tho because it's just tie wire that's heatshrinked. Thanks again Ill take all that into consideration.
Unread 08-02-2015, 23:21
AKA: Mr Tanguay
The mushroom style tape that 3M provided in this year's KOP works well in holding down our router. Our's sits right on top of our electronics box and doesn't budge an inch despite some rather aggressive driving maneuvers experienced during testing.
Unread 09-02-2015, 08:33
Nice job!
I agree with...
I'd say y'all did pretty good from the looks of it! Just make sure that the main breaker is always easily accessible from the outside of the bot!
As to the screw type of connectors, the most often made mistake with these is not stripping enough insulation from the wire. These terminals want some copper to extend through the terminal and out the other side before tightening the clamp. If wire strands ride up the threads, they are not conducting current. Most electrical suppliers, (Home Depot included) will have terminals that do not use a screw against the wire for clamp. Those terminals are meant for large diameter strands and solid wire. The type that uses the screw to push on a metal clamp work better for fine stranded cables.
Unread 09-02-2015, 14:20
Sperkowsky's Avatar
Yes that may have been the batter way but oh well we learned. We did do it the more secure way so atleast we know it's not going to fall out .
Unread 09-02-2015, 14:21
Sperkowsky's Avatar
Nice job!
I agree with...
Alright thanks for the advice.
Do you think making a lexan cover and cutting a hole in it for the breaker Is good.
