| Thread Tools |
Rating:
Display Modes |
#46
Re: Unique robot design?
We just do our best.I also see some carbon fiber on your robot. We may incorporate carbon fiber, but at this point in the season, we may not. We didn't make use of carbon fiber last year either. If we're struggling on weight, some carbon fiber parts may need to be made. Our intake is like this! See Attached: Robot #3 is on its way! Last edited by bEdhEd : 08-02-2015 at 02:54. |
#47
That looks really sweet. I see that you guys either shortened or lengthened your wheelbase in your second iteration (I'm guessing the longer one is the newer one). You're right, they do look like mandibles. Ours is similar, though we've limited the range of motion more since they fold vertically.
We did do the belly in carbon fiber this year; one of our big goals was to teach the kids to do layup, and it's gone really well. We've also experimented with other parts, like gussets. Another big goal was to get the comp bot powder coated, and I'm pleased to say it will get back to us from our new sponsor Blue Flame on Wednesday. May as well post the rest of the pictures now too. The first is our stack of sliders; the second is the full bot as she stood yesterday. |
#48
Full bot.
#49
The new one's shorter, and the even newer final one will be an inch shorter than the short one in the picture. We can continue this conversation as a PM if you wish.
#50
meet the requirements of a STACKED TOTE SET, at the end of AUTO." Also if you score 7 of your Litter pieces in RCs than you can score the other 3 pieces as unprocessed litter for 4pts each. You cannot score the opposing alliance's 4 pieces as unprocessed litter without incurring fouls. And speaking of incurring fouls the maximum score gets really interesting when you consider teams accidentally spilling their game pieces onto the other side of the field. There are no rules that say you cant score those pieces. Additionally if they descore your game pieces when they knock their game pieces over the step you gain the points they descored at the end of the match. Again, nothing says you cant rescore those pieces so that could increase your max score. |
#51
I'm sort of surprised that, in all the discussion about accessing the recycling containers on the step, people are only talking about ways to reach over the landfill. Why not just move it? |
#53
- We think it's faster to pull them over than to move the totes first. - The land fill is a nice and organized area to pull totes from. Why would you want to mess that up when you can practice an efficient pattern at stacking and sorting them from their known starting position. |
#54
We had a team of students and a mentor prototype mechanisms to do this for about a week, ranging from a cow catcher to a curved "tote redirector" that drove along an alliance wall. The cow catcher / snowplow designs for us were pretty terrible at getting much past the first layer of totes once you built the entire wall configuration. The "tote redirector" may have worked if we had lined it with idler wheels (think 1717's spine last year), but at that point we decided we weren't winning the auton battle and that our intake would be able to clear the 3-4 totes in the way quickly enough for qualifications in teleop.
#56
![]() I suspect scorpion part is the one that loads noodles into the can? |
#57
That's correct.
#59
#60
So the concept behind the snow plow is based more or less on playing pool. When you start up a game you break apart the triangle of balls and then pick off easy shots. If you look at our robots design you will see that it can handle multiple totes at once, but the time it takes to get to these totes and be ready to pickup isn't instantaneous, we have a lift we need to adjust (we got rid of a lot of alignment time with el toro but its still there). When we crack open the field or goal is to space totes out so we have quick pickup lines and no idle time where the gap between two totes is large enough that our mechanisms are ready to pickup a tote by the time we get to our next tote. The other advantage of this as in pool is when you break it open you have the chance of moving totes closer to where you need them. With vision drivers should be able to quickly identify pickup lines by tote orientation and looking for basic patterns one of the key ones I imagine is a path of totes roughly in the same orientation that starts close to the scoring platform dives a bit into landfill then comes back out. What I do not want to happen is that drivers get stuck in the habit of going for the closest tote to them when picking lines and spending time on a stubborn tote. I can see that happening a lot to teams that are keeping the starting pattern they only pickup totes in a certain order when in reality that order might not be the best. Breaking apart the totes should make those decisions on which tote to go to next much more clear. Edit: Anybody got a better term then pickup lines in retrospect there has to be one... Last edited by IronicDeadBird : 10-02-2015 at 13:48. Reason: Requesting rephrase help: |
