Go to Post oooo can i get bear hugged at monty madness...please big mike, please - Rohith Surampudi [more]
Unread 08-02-2015, 06:16
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Using wood on a robot
http://blog.kidrobot.com/product-pre...wooden-bender/
...the way nature intended
Laminated wood is plenty strong and if there is any doubt; many of you are probably reading this while sitting on a floor supporting your weight on plywood.
One could argue, depending on the scope of the analysis, wood is actually more ecologically friendly. When you consider the way you get your aluminum, steel and plastic and trace it all the way back to the trees, mines and oil wells. Course wood gets a lot less ecofriendly if you use commerical fertilizers.
Unread 08-02-2015, 09:11
scaryone's Avatar
scaryone scaryone is offline
FRC #0058 (The Riot Crew)
scaryone will become famous soon enough
Originally Posted by pastelpony View Post
Team 51, the Riot Crew, built a pretty mean robot completely of wood last year.
Its Team 58 but thanks for the compliment. Look for a lot of wood this year as well.
Unread 08-02-2015, 09:20
scaryone's Avatar
Use Baltic Birch plywood. Advantages often outweigh aluminum. Wood will bend without breaking and bounce back into shape (of course to a limit). We often feel that wood weight vs strength makes birch superior. Also, so darn easy to work with. Over 80 matches last year (and some really rough ones) and the bot looks like it did on bag and tag day.
Unread 08-02-2015, 09:51
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Riot crew always builds such sweet (wooden) machines.
___________________
- Tennyson, Ulysses
Unread 08-02-2015, 14:44
2508electronics 2508electronics is offline
The One Man Electrical Team
FRC #2508 (Armada Robotics)
Team Role: Electrical
2508electronics is an unknown quantity at this point
We use wood as a base and a panel for the electronics all the time. Also, we do what we call "aluminizing" the wood to all of the piece which basically means spray paint it an aluminum color. That gets interesting during inspections occasionally. Last year the inspector went to test continuity to make sure the frame wasn't being used as a ground and put one of the multimeter probes on the "aluminized" wood base and was surprised when we told him it was wood.
Unread 08-02-2015, 14:46
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Wood this year:
spacer inside 1" square aluminum tubing
spacer inside manipulator mechanism
component of manipulator
Previously:
electrical panel
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 08-02-2015, 15:02
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Originally Posted by MrRoboSteve View Post
Wood this year:
Previously:
electrical panel
Wood this year:
Robot
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
