Go to Post You know, I have 2 big addictions in my life right now: ice cream, and FIRST. While the prior may not be great for my health, I think I'm doing just fine with FIRST. - Beth Sweet [more]
Unread 08-02-2015, 08:45
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Dual Acting Cylinder used as a single
Not a legal issue, but a reliability issue. Ensure that you have enough return force that you don't end up with the piston getting "stuck" in one position. Also consider situations in which something falls into the wrong place - with a dual-acting cylinder, you have a bit more capability to work the piece free.
If you have enough ports and valves available, you may want to consider using separate solenoid valves for the two cylinders, so you can use this only when needed. If you want to do this using the FRC-standard solenoid valves, plug the unused "A" or "B" ports so you aren't dumping air from your tanks when you're dumping air from the cylinders.
