Go to Post The real reason I am coming to IRI is to get that Paul Copioli, he will be bearhugged, if its the last thing I do :p - Mike Schroeder [more]
Unread 07-02-2015, 22:13
Re: Error problems
The problem is your motor code only runs once when the robot starts and never again, because of where you placed it in Periodic Tasks.
Two solutions:
  1. Move the motor code to Teleop.vi, because Teleop gets called over and over again by Robot Main, so your motor code will get called every time new joystick commands are received.
  2. Move the motor code into the 10ms loop in Periodic Tasks. Because that loop gets repeated over and over again, calling your motor code over and over again.
Unread 08-02-2015, 08:47
Team5709 Team5709 is offline
FRC #5709
Team5709 is an unknown quantity at this point
Re: Error problems
ok i will try it today and i'll let u know if it works
Unread 24-03-2015, 15:05
FRC #5709
Thanks to every one who helped we did get are robot running in time to compete
Unread 13-05-2015, 08:45
aeastet aeastet is online now
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
Re: Error problems
Where are you at in Michigan? I might be able to help. If not I know other teams all over Michigan. This might be useful for next year.
Tim
