Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Unread 08-02-2015, 09:01
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Filling pneumatic system in queue?
Hi all!
We're trying to find a rule that says anything about starting up the robot and running the compressor to fill up our pneumatic air tanks. We are using an on-board compressor.
Thanks!
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 08-02-2015, 09:37
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
That is completely okay. My team did all last year too, and I think we plan on doing it this year too.
Unread 08-02-2015, 09:40
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Filling pneumatic system in queue?
Originally Posted by JohnM View Post
That is completely okay. My team did all last year.
This years rules =/= last years rules.
That said, it is legal to pre-charge your tanks before going on to the field.
___________________
- Tennyson, Ulysses
Unread 08-02-2015, 10:35
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Most teams use an extra battery in the que to pre-charge.
Unread 08-02-2015, 12:08
mackenzieg's Avatar
mackenzieg mackenzieg is offline
AKA: Mackenzie Glaser
FRC #1261 (Robo Lions)
mackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of light
My team did this last year. I'd suggest bringing a battery with you in queue to fill the tanks, then switch to a new battery right before the match starts.
____________________
Mackenzie Glaser
Team 1261
Unread 08-02-2015, 12:31
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
When we get back to the pits we do whatever repairs and updates we need to do with the last match battery still in the bot. Before we go out to queue we charge the pneumatics with that battery and then install a new one.
If your system is leaking enough to require a recharge while in line after precharging in the pits you need to work on the pneumatic systems to eliminate leaks.
As a caveat, we have been know when running late to perform the fill and battery change in the queuing line instead of in the pits.
Unread 08-02-2015, 20:47
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Note that you still have to use the control system to fill the tanks; you can't just connect a separate battery directly to the compressor.
Unread 08-02-2015, 21:01
Originally Posted by Daniel_LaFleur View Post
Here ya go: :-)
Unread 08-02-2015, 21:08
"<>" also works.
Unread 08-02-2015, 21:14
"<>" also works.
Unread 08-02-2015, 22:08
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Or from some other infix languages I've used over the years:
~= (MATLAB)
.ne. (FORTRAN)
-ne (Bourne Shell)
/= (Ada)
Unread 08-02-2015, 22:26
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
~= (MATLAB)
.ne. (FORTRAN)
-ne (Bourne Shell)
/= (Ada)
And JavaScript has !== in addition to !=.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 08-02-2015, 23:16
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
This is legal provided you don't break any other rules in the process. I imagine this year during the time you assemble your robot, you could charge your tanks. (Provided it is safe to do so.)
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
Unread 08-02-2015, 23:21
Nuh-uh. You're on the field, putting your robot together, it's either off or disabled. The compressor only runs when the robot is enabled. And tethering up is illegal.
Now if you're changing from one Transport Configuration to another within the same volume, sure, knock yourself out, because you're in queue for that. (Just don't leave Transport Configuration to do that.)
Unread 08-02-2015, 23:24
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
But it won't be.
As pointed out by FIRST through some rule changes about re-enabling after a match noted that to do so could be dangerous for the volunteers getting the field ready for the next match. Even if you are just charging your pneumatics things could happen where your robot moves or does something unexpected that a volunteer isn't looking out for.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
