Go to Post 2010 game piece--- participation medals - johnr [more]
Unread 08-02-2015, 16:34
Light Boko Light Boko is offline
FRC #2557
Light Boko is an unknown quantity at this point
Rangefinder Radar on SmartDashboard
I have been trying to create a radar-type graph on my team's smart dashboard. What I want it to do is, since our rangefinders are on 180 degree servos, is to have a line plot that instead of using time, it uses values 0 - 180, that would print to the graph based on the current angle our servo is on. I want it to go back and forth(whenever it reaches 180 it goes into reverse back to 0, and vice-versa) and wipe the angles previous data. If anyone could help me find out how to do this, it would be very much appreciated. Thanks!
Unread 08-02-2015, 21:11
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: Rangefinder Radar on SmartDashboard
You can try making your own control in the new smart dashboard using this guide. The guide itself is for a different kind of object but the concept should apply to what your trying to do.
Unread 09-02-2015, 15:21
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I haven't looked at the SmartDashboard graphs, but in other IDEs I've been able to "wrap" angles and not get a vertical connection by including a point with a "NaN" in the data stream after the last one at one end and before the first one at the new end.
Unread 09-02-2015, 19:30
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
That's really cool! I kinda want to do that
