Go to Post Off-season events aren't just for gameplay, they should also be a training session for new students and rookie teams. - Bill Moore [more]
  #31   Spotlight this post!
Unread 02-02-2013, 10:06
Re: remainder function
Originally Posted by Radical Pi View Post
drem() does exist, and is defined to be the same as remainder() (see the glibc manual).
Apparently in glibc, remainder() and drem() are two different names for the same function
Notice the very slight difference between the glibc and Java definitions (handling of divide-by-zero).
  #32   Spotlight this post!
Unread 02-02-2013, 11:14
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
The "java" link you posted was to gnu libc...
Proud alum of CORE 2062.
www.core2062.com
  #33   Spotlight this post!
Unread 02-02-2013, 11:27
Fixed. Take a look.
  #34   Spotlight this post!
Unread 08-02-2015, 16:56
Originally Posted by Joe Ross View Post
Here's the result from the robot
        double result;
        double x[] = {179, 180, 181, 359, 721, -1, -179, -180, -359, -361, -721};
        for (int i = 0; i < x.length; i++){
            result = MathUtils.IEEEremainder(x[i],360.0);
            System.out.println("x: " + x[i] + " rem y: 360 result: " + result);
Joe, is the MathUtils.IEEEremainder() method available in 2015 FRC Java, now that the runtime engine has changed? If so, does it produce the exact same results?
  #35   Spotlight this post!
Unread 08-02-2015, 17:32
It's in Math, rather then the squawk MathUtils workaround, but it still works.
x: 179.0 rem y: 360 result: 179.0
x: 180.0 rem y: 360 result: 180.0
x: 181.0 rem y: 360 result: -179.0
x: 359.0 rem y: 360 result: -1.0
x: 721.0 rem y: 360 result: 1.0
x: -1.0 rem y: 360 result: -1.0
x: -179.0 rem y: 360 result: -179.0
x: -180.0 rem y: 360 result: -180.0
x: -359.0 rem y: 360 result: 1.0
x: -361.0 rem y: 360 result: -1.0
x: -721.0 rem y: 360 result: -1.0
  #36   Spotlight this post!
Unread 08-02-2015, 19:00
Thanks Joe.
For those of you reading this thread for the first time, Math.IEEEremainder(angle,360.0) can be used to convert any angle (in degrees) to the range -180 to 180.
This can be very useful when working with the gyro.
Let's say you want to find the shortest angular error between your joystick direction angle and the gyro angle. This can be accomplished in one clean line of code as follows:
angle_error = Math.IEEEremainder(joystick-gyro,360.0);
There's no need for conditional logic. It cleanly handles all input angle ranges for joystick and gyro, including angles greater than 360 degrees and less than -360 degrees.
The above assumes that gyro and joystick share the same zero and measurement direction.
