Go to Post Not sure if its fair to call this or not yet. Back a group of dedicated teenagers far enough into a corner, and they're gonna find a way out. - Racer26 [more]
Unread 08-02-2015, 19:53
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Talon SRX Missing Encoder Counts in Labview
What exact model number S5 are you using?
How fast are you spinning it?
We have:
S5-1000-250-I-S-N
Is the model number.
I know the output shaft ratio, it's 4.71:1 soo...lets see according to VEX the encoder shaft is 3 times the output shaft... Maybe approx 3375 RPM? Does that sound right?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 08-02-2015, 20:05
Originally Posted by Chris_Elston View Post
We have:
S5-1000-250-I-S-N
That's a 1000 CPR encoder. It's 4000 PPR at 4X.
That's 4.4 microseconds per edge, assuming zero tolerance on symmetry and quadrature delay.
I could not find symmetry or quadrature delay specs in the S5 datasheet.
The S4 datasheet has max quadrature delay tolerance of 60 electrical degrees. I doubt the S5 is that bad (because the disk is assembled at the factory, not by the user), but just for comparison: with a quadrature delay tolerance of 60 electrical degrees, the microseconds per edge could be as fast as 1.5.
