Go to Post This is one area where you want an old hand in the room to show you how to work on this thing. .... If you survive it, electricity hurts really bad. - ebarker [more]
Unread 08-02-2015, 21:58
adampaskowitz adampaskowitz is offline
FRC #4345
adampaskowitz is an unknown quantity at this point
Re: No compressor light on PCM, no compressor power, no CAN recognition of compressor
You're right. Thanks. I'll switch it back, but I honestly didn't notice any difference between the way the robot responded when wired with either of those two arrangements.
Unread 09-02-2015, 12:54
feverittm's Avatar
feverittm feverittm is online now
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
If your CAN is hosed (disconnected of wired wrong) you will get a red light on the PCM status indicator. Make sure everything is green.
Check your pressure switch. It should be a normally closed switch, so you should sense continuity (using a meter) across the wires going into the PCM.
If the status is green, and the switch if closed, but are the PCM indicator is flashing showly, and the compressor will not start, then it probably still disabled and you need to look into the code.
Please also remember the code suggestions given above. The compressor WILL NOT start unless either the compressor/PCM is defined in the code or there is some pneumatic element (solenoid) defined.
If you don't have any solenoids defined you will need to define the compressor:
public status final Compressor myCompressor = new Compressor(0);
We had this problem over the weekend and it took a few hours to figure this out.
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
