Go to Post Take care of what's there and you never need a replacement. - Rich Kressly [more]
Unread 08-02-2015, 23:27
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Re: TI Launch Pad Button Not Working
Originally Posted by wt200999 View Post
I was able to replicate this in a VM. In addition to your description, I also tried 'soft' disconnecting the device from the Windows VM (board itself stays powered) and reconnecting it, and I still was unable to get button inputs. So in this case the device requires a full reset.
On that note, and while not optimal, you can use the RST button or pin to force a reset. That seemed to work on my end to get the button inputs responding again.
Also rescanning or using F1 did not work to get the buttons responsive again.
I've submitted a bug for this on Github and we will take a look at it.
Guess we'll plan to make the reset button accessible from outside the box. Thanks for the "heads-up".
