Go to Post I love how your suggestion for MCC is one of the most elite robots of the year, and one of the World Champions. I also love that I really can't argue with you. - JVN [more]
Unread 09-02-2015, 08:04
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
Re: motor programming
Originally Posted by itwasntme455 View Post
What is the wait 20 for in the bottom left corner?
The wait 20 is in there because this loop is designed to be dropped in Periodic Tasks and run in parallel with Teleop (which should contain your drive code). The wait command actually releases the processor to do other things for a split second then come back and rerun this loop.
Please note two things. 1) the code posted by Mark is a snippet, you can download the picture and drag it into LabVIEW and it will turn back into code.
2) it is advisable to move the part that he has labeled labeled for teleop into the loop (one joystick gets values, one index array, three branches of the button value) - mostly because these actions are related (increase cohesion).
