Go to Post FIRST doesn't end after your last year within a team. It's never going to end. - Tetraman [more]
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Unread 09-02-2015, 09:03
Al's Annual Inspection Thread 2015
OK, it is that time again so I will start here with Bumpers (Yes, I have had several teams report that they intend to add bumpers this year).
Yes, you can add bumpers this year but they are entirely optional and...
1. They must be weighed as part of the robot weight, and that total cannot exceed 120 Lbs, R4.
2. The bumpers when attached must also fit in the TRANSPORT CONFIGURATION R3.
3. Bumper construction will be inspected for potential safety hazards and attachments like any other robot parts.
3. As bumpers are entirely optional, they do not need to cover specific areas of the frame perimeter.
4. Bumpers do not need to be constructed as suggested in the Bumper Design Guide found here. Be aware that the guide is a tried and tested design.
In addition to the rules as published, Team Updates come out on Tuesday and Friday each week. If Team Update changes or modifies a robot rule, that change will be part of the inspection process at subsequent events.
I would like to point out a Team Update was published Friday, 2/6/2015, concerning custom MXP boards. This is not a change in the rule but a clarification to make it easier to understand and flow chart is included. Restated, if you have any active components on your custom made MXP board and you are using any of the PWM outputs on the MXP connector for controlling motors or servos, the board can only be one of the three pre-approved boards listed in R58.
More to come later...
Unread 09-02-2015, 09:13
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Al's Annual Inspection Thread 2015
Unless you're going to install the bumpers (in under 60 seconds) once you reach the playing field.
Unread 09-02-2015, 09:52
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
However, they are still taken into account for Transport Configuration, wherever they are stored on the Robot.
Maybe delete "when attached" from the bullet point.
Unread 09-02-2015, 10:32
I would like to point out a Team Update was published Friday, 2/6/2015, concerning custom MXP boards. ...This is not a change in the rule but a clarification to make it easier to understand and flow chart is included. Restated, if you have any active components on your custom made MXP board and you are using any of the PWM outputs on the MXP connector for controlling motors or servos, the board can only be one of the three pre-approved boards listed in R58.
Is a simplified interpretation: "Except for the pre-approved boards, and boards with no components (board is only line traces), No connection from the MXP board to a Motor Controller."?
Any thoughts on why Custom Circuits cannot be used for PWM, but are allowed on the CAN Bus, and thus might be controlling the Motor Controllers?
Unread 09-02-2015, 10:40
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I believe that this is in keeping with R57:
Originally Posted by 2015 Game Manual, R57
Every relay module, servo, and PWM motor controller shall be connected to a corresponding port (relays to Relay ports, servos and PWM controllers to PWM ports) on the roboRIO or via a legal MXP connection (per R58). They shall not be controlled by signals from any other source.
As I interpret it, they are trying to ensure that when they issue the "disable" command, that they are certain that it will have that effect. This is both a safety and a game issue.
Unread 09-02-2015, 10:41
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Because R59 say all motor controllers on the CAN Bus must be controlled by the RoboRIO and R62 says CUSTOM CIRCUITS or other devices that interfere with those communications are not allowed.
Unread 09-02-2015, 11:14
Gus,
The TRANSPORT CONFIGURATION will be determined during inspection at the same time as weight. Under Tournament rule T6 there is no provision for removing bumpers to determine size limits.
T6 While transferring the ROBOT throughout the event (e.g. between the Team’s Pit, Practice Field, ARENA, Inspection Station, etc.), the ROBOT must not exceed a volume that is 28 in. wide x 42 in. long x 78 in. tall (the TRANSPORT CONFIGURATION).
(Emphasis is mine.)
Safety is our prime concern for everyone involved. As such, nothing may cause robot movement until and during the times the robot is enabled by the Field Management System.
Unread 09-02-2015, 11:18
Gus,
There is also no rule requiring bumpers be attached at their operating position for Transport Configuration. During TC, the bumpers could be sitting inside the robot, and on the field quickly attached with pins.
Unread 09-02-2015, 11:25
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Gus,
(Emphasis is mine.)
I'm not getting this Al. Why can't I remove my bumpers, store them inside the bot, and transport my bot to the practice field, arena, inspection area, etc. Check the weight & TC volume with the bumpers stored inside the bot, and then put them on if needed for additional inspection, just like I'd put any other attachment on after transporting to the inspection station. Since your quoted rules never mention the word BUMPER, how does your bumper restriction not also apply to any other attachment that must be relocated for transporting?
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 09-02-2015, 12:43
John and Rich,
It is my understanding, that bumpers, if used, are part of the robot, just like an arm, a pickup device or the control system. That means that the bumpers are not considered separate of the ROBOT and all rules apply. As such, the bumpers need to be mounted on the robot for weight and size. I suppose you can (for this year only) have bumpers on moveable parts that retract the bumpers into the robot for determining the TRANSPORT CONFIGURATION. Just as in the past, if you have multiple devices that can be used on your robot, all mechanisms must be weighed together, and the overall size will need to be determined for each configuration under R4. The change in the bumper rules applies to this season. There is no telling what next season will bring.
Unread 09-02-2015, 12:47
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
John and Rich,
Al,
R3 allows for minor disassembly to be made to get the robot into its transportation configuration. This would allow them to take the bumpers off and place them somewhere on the robot inside the size constraints. Then when they get on the field they would be allowed to reattach them prior to the match.
Unread 09-02-2015, 12:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Al - Is the only option retraction for bumpers? The blue box under R3 states the TRANSPORT CONFIGURATION size constraints can be met with "minor disassembly"., And references G10, which gives a guideline of 60 seconds for on field configuration. I guess the question boils down to the definition of "minor disassembly". Having a set of bumpers that can be removed and placed inside the robot for transport, then attached quickly with a couple of wing nuts seems to me to meet the intent of the rules.
2016: Lake Superior WFFA
Unread 09-02-2015, 12:58
ATannahill ATannahill is offline
AKA: Alex Tannahill
Al,
I can see situations where the only time certain parts, not limited to bumpers, are mounting on the robot is outside of transportation configuration. The rules allow for pieces to be removed from the robot to make it fit in the TC. If all parts of the robot are to be attached at weighing, the robot should not be expected to be within TC. Simply put, being within the TC and having all parts attached might be mutually exclusive for some robots.
Unread 09-02-2015, 13:17
'Bumper' is not even a glossary item and as such appears to have no special distinction as compared to other attachments or robots components/assemblies/mechanisms. In fact, there is no definition of where the boundary between a bumper and a non-bumper element is. If I want to call my steel bar located in the center of my robot a bumper, there is no rule that says I can't do so, and doing so has no impact on any aspect of the rules, as near as I can tell. Heck, I can claim my RoboRio is doing double duty as my bumper.
Edit: Having said all that, there is much practical benefit to not having teams remove and attach bumpers for every match. We've seen how that works in the past for many teams, but I don't think the rules speak to the issue.
John Vriezen
Unread 09-02-2015, 14:27
AustinShalit's Avatar
Happy Birthday! AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Hi Al,
I am a bit confused. I thought that bumpers could be attached on the field as long as they go on within 60 seconds (or reasonable time) G10 & G11 and fit within the TRANSPORTATION CONFIGURATION. For example, if I have an upright on the robot (that only rises 6ft) and I use a bungie cord to temporarily secure my bumpers to that upright that is legal within the rules? Does Q&A Q189 say that that bungie cord would not count against the total robot weight?
Thanks,
Austin
