Go to Post [on reputation] They're just dots. - Brandon Martus [more]
Unread 09-02-2015, 09:50
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Failed pinion gear install: AM-2195 to BaneBots P60
We were installing the BaneBots 15T 3.2mm pinion gear on the AndyMark AM-2194 motor this weekend. We install them by carefully placing the pinion on the end of the motor shaft, placing the unit in a vice, and slowly closing it.
The first pinion we installed works fine. The second one was loose on the shaft. It looks like, rather than deforming around the shaft of the motor, the inside of the hole was peeled away by the motor shaft. I checked the shaft and it's fine dimensionally and otherwise, reading right at .125.
I'm going to order more pinions, but am wondering whether there is something additional we should be doing during the install to prevent this from happening.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 09-02-2015, 12:55
cfair cfair is offline
AKA: Chris Fairley
None #1351 (AMHS Robotics)
cfair is an unknown quantity at this point
Re: Failed pinion gear install: AM-2195 to BaneBots P60
I would try heating the pinion before you put it on. And if you have an arbor press, that's what you should be using. But I've done exactly what you described before without trouble. Crappy pinion?
Unread 09-02-2015, 16:33
AKA: Steve Peterson
Heating is a good idea -- will get out the hot air gun and give it a shot.
Unread 09-02-2015, 20:41
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
We like to use a torch to heat pinion gears, we'll set the gear on the steel base of our hydraulic press and heat it until she's cherry red. Then press motor into gear and allow ample cooing time. Just be careful! That pinion wouldn't be too comfortable to touch.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 09-02-2015, 20:59
Originally Posted by Jpatterson1710 View Post
We like to use a torch to heat pinion gears, we'll set the gear on the steel base of our hydraulic press and heat it until she's cherry red...and allow ample cooing time.
I take it the pinion gears you use are not heat treated?
Unread 12-02-2015, 22:02
mentorDon's Avatar
mentorDon mentorDon is offline
FRC #1764
mentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these parts
For a light press fit, a little light machine oil should be used. This helps to prevent galling between the surfaces as they slide together. Heating them until red hot and letting them cool down without quenching would soften/normalize any previous heat treatment. There are 'air hardening' tool steels, but it properties wouldn't be useful for gears.
Also make sure you are pressing against the opposite end of the motor shaft and not the motor body.
