Go to Post Now THAT's the way FIRST is supposed to work :) ! - Stu Bloom [more]
Unread 09-02-2015, 10:09
Kalvin1105 Kalvin1105 is offline
FRC #4229
Kalvin1105 is an unknown quantity at this point
Wiring Question
Hello i'm Phuc from team 4229. We are using actuators this year and ran into a problem of sorts with getting the actuators to run at the same speed. Does anyone know if it is against the rules to hook up two motors to the same jaguar or talon? I tried looking through the rule book but couldn't find anything about this. Thanks.
Unread 09-02-2015, 10:10
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Wiring Question
See rule R42 and Table 4-4 in the Game Manual.
It depends on the type of motor.
If you are using PWM, you can use a splitter cable to send the same signal to two motor controllers.
If you are using CAN, you can set one motor controller to follow the other.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 09-02-2015, 10:13
TylerStaudigel's Avatar
TylerStaudigel TylerStaudigel is offline
FRC #0144 (R.O.C.K)
TylerStaudigel is an unknown quantity at this point
Re: Wiring Question
Be sure to check that the amperage that the motors would pull does not exceed the potential output of the jags.
Unread 09-02-2015, 10:18
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Wiring Question
The problem is more likely that the actuators are responding differently to the same input; if this is the case, putting both of them on the same controller wouldn't help. If you really need the two actuators to move in sync, there are two basic solutions:
  1. Hardware. Create a linkage such that the two actuators must always be at the same locations. This would not necessarily need to be as robust as if you were trying to drive things with just one actuator, but it must be good enough to equalize the differences.
  2. Feedback sensors. Whether encoders or string potentiometers, put a sensor on each actuator and adjust the speeds to each so that they move together.
Unread 09-02-2015, 10:19
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: Wiring Question
R42 clearly covers this topic. "Each power regulating device may control electrical loads per Table 4-4. Unless otherwise noted, each power regulating device may control one and only one electrical load."
Using talon or jag is not one of the exceptions.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 09-02-2015, 10:34
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Wiring Question
According to R42 (second row of table), the following motors may be used with "Up to 2 per controller":
  • Automotive Window/Door/Windshield
  • Wiper/Seat Motors
  • AndyMark PG
  • Bosch Motor
  • Snow-Blower Motor
  • Denso Throttle Control
The list of controllers is R41 (A), and includes both talon, R41(A)(B); and jag, R41(A)(A).
Unread 09-02-2015, 12:33
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Just use 2 talons/jaguars/victors but connect them with one spit pwm cable.
Unread 09-02-2015, 14:47
RossMN RossMN is offline
FRC #4229
RossMN is an unknown quantity at this point
Re: Wiring Question
And what are we supposed to assume if our motor doesn't fall into one of those categories? Why doesn't FIRST simply state current or power limitations?
Unread 09-02-2015, 14:52
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Wiring Question
Read Rule R18 (emphasis mine):
The only motors and actuators permitted on 2015 FRC ROBOTS include the following...
If it isn't in the list, you aren't allowed to use it at all.
Unread 09-02-2015, 15:01
FRC #4229
Re: Wiring Question
  • Wiper/Seat Motors
  • AndyMark PG
  • Bosch Motor
  • Snow-Blower Motor
Yikes, so this part is illegal?
http://www.progressiveautomations.co...4sec-p-35.aspx
If I'm reading this correctly, we're in pretty big trouble.
Unread 09-02-2015, 15:05
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Wiring Question
the motor on that actuator looks a lot like a CIM. If you can take a legal CIM and stick it on that actuator you are back in action.
The restriction is on the motors we can use not what they are connected to.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 09-02-2015, 15:07
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Wiring Question
Many teams have used such COTS linear actuators by replacing the actual motor with one of the motors allowed. In effect, they use the "gearbox" portion of the actuator with an allowed motor. See R18 for the full list - the list above is just the ones which can be duplexed on a single controller. The key things you're going to need to match are shaft, torque, and speed. If you then have several matches, look at mounting options.
Unread 09-02-2015, 15:11
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Wiring Question
You might need to replace the motor with another legal one, like a CIM or MiniCIM.
Is your team going to be at one of the week-0 scrimmages this weekend? If you let me know which one, I can try to stop by to help at some point and make sure it's legal!
2016: Lake Superior WFFA
Unread 09-02-2015, 15:15
FRC #4229
Re: Wiring Question
We'll be at the week 0 event at Central High School in Saint Paul
Unread 09-02-2015, 15:26
Mentor, LRI, MN RPC
Re: Wiring Question
Great! Do what you can to make sure it's legal and functional this week, I'll stop by there on my way down to Simley and look for you guys between 8 and 8:30 Saturday morning. Get there nice and early!
