Go to Post This year it is what it is and, at some point, we will all find out what that is, specifically. - JaneYoung [more]
Unread 09-02-2015, 10:00
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Re: Filling pneumatic system in queue?
Alright, I got my answer. Thanks everyone!
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 09-02-2015, 11:12
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Nuh-uh. You're on the field, putting your robot together, it's either off or disabled. The compressor only runs when the robot is enabled. And tethering up is illegal.
Tethering is only illegal on the field (violation of G9). There is no prohibition on tethering in the que. One rule to be careful of: Don't move the robot out of transport configuration while in the que (Q299).
Unread 09-02-2015, 12:55
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
We've got an onboard compressor, and we made use of our older larger compressors by mounting three on one board so we can attach our robot to these offboard compressors, which are powered by their own battery, thus eliminating the need to tether. With three bigger compressorsrs charging the robot while it is off, we save onboard battery power, and fill up our tanks to the right pressure in less than a mere 10-20 seconds, to my estimation. I'll have to time this process so I have a concrete number.
Unread 09-02-2015, 12:57
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Originally Posted by bEdhEd View Post
We've got an onboard compressor, and we made use of our older larger compressors by mounting three on one board so we can attach our robot to these offboard compressors, which is powered by their own battery. With three compressors charging the robot while it is off, we save onboard battery power, and fill up our tanks to the right pressure in less than a mere 10-20 seconds, to my estimation. I'll have to time this process so I have a concrete number.
This is NOT LEGAL!!!!!
Unread 09-02-2015, 12:58
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
This is not legal. Or safe.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 09-02-2015, 13:04
ATannahill ATannahill is offline
AKA: Alex Tannahill
Frank,
All air on the robot must come from ONE compressor with a max flow rate of 1.05 controlled by the roboRIO. Your team agrees to this when signing the inspection sheet.
Unread 09-02-2015, 15:43
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Just to be specific, here is the rule:
Originally Posted by Rules
R68 Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not
exceed nominal 12VDC, 1.05 cfm flow rate.
___________________
- Tennyson, Ulysses
