Go to Post I'm intrigued by the possibility of Mayan stadium sports, minus the whole sacrificing part. - AlecMataloni [more]
Unread 09-02-2015, 16:03
ale_jero ale_jero is offline
FRC #5215
ale_jero is an unknown quantity at this point
Question Autonomous Pneumatics Question
How can you program pneumatics (open/close) for Autonomous.
Unread 09-02-2015, 16:41
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Autonomous Pneumatics Question
Do you already have an autonomous routine running with motors (e.g. your drive system), or are you really asking how to create an autonomous routine? (I don't know the answer for LabView either way, but I know that the gurus will need this info.)
Unread 13-02-2015, 02:09
Optimism's Avatar
Optimism Optimism is offline
AKA: Calvin Ly
FRC #2468 (Team Appreciate)
Optimism is an unknown quantity at this point
There are built-in tutorials for pneumatics in LabVIEW, and although those are not specifically designed for autonomous, they give you a good reference. For autonomous, you will likely want to perform a sequence of actions, so use a Sequence Structure to designate the order of actions. Make sure to initialize your solenoid and start your compressor in begin.
