Go to Post Im ready for anything. - davidthefat [more]
Unread 09-02-2015, 20:18
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
Constant running motor
Our team is having issues with controlling a new motor. We followed an example online and CAN control the motor, but when you take your hand off the control, the motor is spinning. We switched controllers just in case with no luck.
What in our program here could be causing this?
Unread 09-02-2015, 20:26
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Constant running motor
You need to remove the '0' you have at the top (and leave the terminal disconnected).
If you look inside the Joystick "Get Values" function, you will see that the value received from the joystick is divided by this value. And since you cannot divide by 0, LabVIEW calls this infinity. Finally it puts it in the 1 to -1 range, so it will always output '1', which is full speed forward.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
