Go to Post Collaboration works. DO IT. - Travis Hoffman [more]
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 09-02-2015, 15:47
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: Al's Annual Inspection Thread 2015
James, while there is no pneumatic rule that this violates what you will have is essentially a device that moves on it's own without being enabled by the FMS. Potentially that could be a violation of R8.
If thats an issue with R8, wouldnt that mean that any mechanism that is run off of a single solenoid, or any mechanism that moves when air is vented be illegal at that point? We can't control gravity, which causes alot of devices to move when the robot is disabled.
Team 4488 - Mentor 2013-2016
  #32   Spotlight this post!
Unread 09-02-2015, 15:52
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
So everyone, I am in contact with HQ now over this question. Give me a day or so to straighten this out.
Al,
I have thought about this and I would suggest that it is no different from a typical air cylinder in most regards. It will not change state unless (a) the compressor kicks on and charges air, which only happens when enabled; or (b) the venting valve is opened, in which case ANY air cylinder could move. The only functional difference I can come up with is compared to 'one-way' solenoid valves, that default to a given state when disabled or de-powered, in which case the 'always connected' air cylinder is safer, because it doesn't change rapidly or without explicit input (venting air pressure or charging air pressure).
  #33   Spotlight this post!
Unread 09-02-2015, 16:33
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Originally Posted by JamesCH95 View Post
any excess pressure will be vented by the regulator.
I would confirm that if I were you. Some regulators block all air going in the reverse direction, and do not have a way to vent excess pressure.
  #34   Spotlight this post!
Unread 09-02-2015, 16:41
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
The 'black Norgren' regulator specified by the pneumatic section of the manual vents excess pressure for exactly this reason.
  #35   Spotlight this post!
Unread 09-02-2015, 16:42
Then that regulator is not a legal regulator. According to R71 the main regulator must be a relieving regulator.
  #36   Spotlight this post!
Unread 09-02-2015, 17:27
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
John and Rich,
It is my understanding, that bumpers, if used, are part of the robot, just like an arm, a pickup device or the control system. That means that the bumpers are not considered separate of the ROBOT and all rules apply. As such, the bumpers need to be mounted on the robot for weight and size. I suppose you can (for this year only) have bumpers on moveable parts that retract the bumpers into the robot for determining the TRANSPORT CONFIGURATION. Just as in the past, if you have multiple devices that can be used on your robot, all mechanisms must be weighed together, and the overall size will need to be determined for each configuration under R4. The change in the bumper rules applies to this season. There is no telling what next season will bring.
Originally Posted by notmattlythgoe View Post
Al,
R3 allows for minor disassembly to be made to get the robot into its transportation configuration. This would allow them to take the bumpers off and place them somewhere on the robot inside the size constraints. Then when they get on the field they would be allowed to reattach them prior to the match.
I'm very confused here. On one hand we have the game manual saying that we're allowed to perform minor disassmembly to fit into the Transportation Configuration, while on the other hand the Chief Robot Inspector for FIRST is saying that it's illegal. Normally I'd just go with the manual, but as I've been told many times on this forum the Lead Robot Inspector is the final authority at events. If there's been a rule change from what's written in the manual to disallow minor disassembly I'd like to know as soon as possible and I also would like to know why this hasn't been addressed in a Team Update.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #37   Spotlight this post!
Unread 09-02-2015, 17:59
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
I can't see how the GDC could suddenly declare the optional non defined bumpers to be required to be attached AND within the Transport Config at this point. I suspect a fair number of teams have quick attach/detach bumpers outside the TC that might also have integrated into them other critical mechanisms/purposes.
But I'm guessing since Al is in contact with headquarters, we'll see something about it either way on Tuesday or Friday, if not before from Al on this thread.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
  #38   Spotlight this post!
Unread 09-02-2015, 18:11
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
R78 (one valve to vent all pressure) essentially requires that cylinders always be ported to pressure (even if it is through a control valve) or atmosphere. enabled or disabled. Both ways would be the same violation of R8. A blocking control valve would potentially prevent this behavior but they are essentially prohibited by R78.,
  #39   Spotlight this post!
Unread 09-02-2015, 18:28
magnets's Avatar
magnets magnets is offline
I have a really hard time believing that minor disassembly/assembly when on the field will be made illegal. My team, and many others (likely including yours) plan to take advantage of this unique rule this year, and have spent money/time designing and building robots that take require assembly on the field. I wouldn't say our whole strategy revolves on being able to manually install a mechanism that's considerably larger than the transport configuration, but we've spent over half our robot budget/time working on it.
We have also come in a little bit underweight, so we do plan on removable bumpers this year that are bungeed to the elevator tower when not in use, and dropped into place when the robot's on the field.
  #40   Spotlight this post!
Unread 09-02-2015, 19:51
I agree with Karthik. No inspector has the authority to override the Manual.*
Let me put it this way: Right now, my team is considering pinning an item or two onto our robot. Push item onto robot, push pin in, compete, remove pin, remove item and stick in robot, away we go. If minor disassembly is not allowed, we will have to add or modify a full subsystem to accomplish the same task. In one week. It would have been nice to know this, say, two weeks ago.
I also agree that we'll probably hear back either from Al or from an Update very shortly.
*If an inspector (or ref, or field staff) does override the Manual, we can usually expect a blog post in apology if it's anything like a major incident, and a Q&A clarifying if it's not a major incident.
  #41   Spotlight this post!
Unread 09-02-2015, 20:02
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
One would hope. In some areas, however, this is not always the case. In particular last year I remember the rules regarding disabling robots temporarily outside their frame perimeters being somewhat liberally applied outside of the manual definitions, sometimes in ways that severely impacted match results.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #42   Spotlight this post!
Unread 09-02-2015, 20:59
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Al asked for a day or so to get an answer on the bumpers or as some call them the BUMPERS. Can we dial back the panic until he gets back?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
  #43   Spotlight this post!
Unread 09-02-2015, 21:37
There are 8 days left in the build season. If this rule has been changed teams will need as much time as possible to redesign their Robots to account for the change. I don't fault anyone for panicking.
  #44   Spotlight this post!
Unread 09-02-2015, 21:51
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
There's a tiny ir reciever on our robot to control the leds. During matches do you think I will be allowed just to put electric tape over it.
  #45   Spotlight this post!
Unread 09-02-2015, 22:00
Electrical tape doesn't block IR very well. Visible light, yes. But IR isn't visible light.
I would suggest aluminum foil instead. But... I would also suggest, and probably more strongly, finding another way to control the LEDs in question.
