Thread Tools |
Rating:
Display Modes |
Re: Blown talon srx modules
We agree on that part. However, I don't consider Talons to be "consumer electronic" devices.
They are, however, a device that are designed with this specific purpose in mind, which should require it to have even better ESD protection.
Better than What? Do you even know what the ESD rating is for the Talon SRX? This would be an important thing for you to know before claiming it is not sufficient. |
Seeing as the data has not been released (that I have seen), of course I don't know what it is. I would expect it should be on the order of 15kV. Anything less than 8kV, I would say is probably insufficient for this application.
So what happens if the ESD event is greater than 15 kV?
Then it fails? I'm not sure what you're getting at.
#7
I agree it should fail. But I would not suggest that the product is crap if it did fail because of this.
#8
Greg,
Could your custom cables be shorting adjacent wires and therefore be shorting things within the Talon? If misaligned, this could be a problem since they're insulation displacement connectors. Moreover, if these cables are faulty, you'd continue to propagate failures. |
#9
Secondly, the 3.3V line is probably a power supply line. The impedance looking into the Talon on that line will probably be quite low making it hard for any outside interference source to have a significant influence on the internal circuitry of the Talon. Basically the internal impedance of the 3.3V line forms a divider with the impedance coupling to your external noise source. Quote:
You may want to twist the new cable assembly (2-4 twists per inch) to make it more resistant to external inductive noise. Running the cable so that runs that are parallel to power wires are 2-3 inches away from the high power wires can also help reduce noise coupling. |
#10
That's really my best guess at the moment. |
#11
I doubt that a Talon would very exceed 100deg C, needless to say 125. I think they tend to stay fairly cool.
#12
The temperature of the case is different than the junction temperature.
#13
Transorbs are a pretty rugged class of devices. I have severely abused similar devices by applying surge voltage test with much higher energy than the ESD test (several 100 x), without allowing the required cool down times and the transorbs worked properly up till the heat dissipated in them melted the solder and the part fell off the board. They continued to work after we soldered the parts back in the board. |
#14
This is an ESD issue, not related to thermal.
So far only two teams have reported this problem. Not several. This is far from the truth. No amount of ESD precautions can guarantee protection from an ESD strike. |
