Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 09-02-2015, 23:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: What motors are you using for your lift?
Our tote lifter is powered by a CIM, through a toughbox, and chain sprocket reduction, which powers a cam, that lifts the arm. Kind of complicated sounding, but it works.
Our container lifter also uses a CIM and toughbox, and even more chain sprocket speed reduction, and it's also counterbalanced with a gas spring, and Latex tubing.
Springs of some sort can really help reduce the load on the motor, if you can figure out a way to use them. Our container lifter is balanced so that it needs to be driven down with a little bit of force when not holding a container, and driven up with about the same amount of force when it is holding a container. This cuts the load on the motor by quite a bit.
