Go to Post Watch out, guys, Lisa's coming.... worse than any hurricane or tornado you can imagine! - KathieK [more]
Unread 09-02-2015, 23:27
zDrakon zDrakon is offline
FRC #3501
zDrakon is an unknown quantity at this point
Lightbulb Vision BoofCV Odroid communicate with Roborio
Has anyone out there found a good step by step link or some team willing to explain just how do you code the Roborio in eclipse to obtain input of the live webcam processed by Odroid on our electrical board. Thanks this would help so much if someone can explain how or what does the Roborio need in eclipse in order to "read" images from the odroid's webcam.
Unread 09-02-2015, 23:33
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Vision BoofCV Odroid communicate with Roborio
you have to be able to send the image to the roborio. if possible try doing the image processing on the odroid and sending the crucial information to the roborio. If you need get a second camera and stream that to the driverstation.
Unread 09-02-2015, 23:44
FRC #3501
We are using the ODROID to process that image, I just don't know if roborio can take the boofcv packages to import an image from the odroid. I think our team tried at first but then resolved to ODROID since the roborio code could not handle boofcv and WPILIB at the same time.
