Go to Post All I want for Christmas is a better game hint, a better game hint, a better game hint... - Schnabel [more]
Thread Tools Rating: Thread Rating: 26 votes, 5.00 average. Display Modes
Unread 02-09-2015, 11:38 PM
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
Re: PID control help
Originally Posted by cstelter View Post
Do you need the position of each encoder to map, or just their rate? In other words, is it OK if one gets up to 100 clicks per second a little ahead of the other and then the two even out to 100 clicks a second? Or do you want the distance on each encoder to be as identical as possible?
We are trying to have each motor at the same speed and if the encoder notices that the speeds aren't the same we would like for the slower one to speed up or the faster one slow down so the speeds are equal. We were thinking that the motors start at the same speed but after a little while of running the speeds my get off, if they do we want to make them equal again. The loop essentially keeps the motors the same speed These motors are controlled by the driver and both with one button.
