Go to Post FIRST is here to inspire you, to challenge you. Part of that process is giving you a task too hard, resources too little, people too many, time too short. - ebarker [more]
Unread 09-02-2015, 23:43
Vladi03's Avatar
Vladi03 Vladi03 is offline
@Ivan_the_Czar
AKA: Ivan Salazar
FRC #0399 (Eagle Robotics)
Vladi03 has much to be proud ofVladi03 has much to be proud ofVladi03 has much to be proud ofVladi03 has much to be proud ofVladi03 has much to be proud ofVladi03 has much to be proud ofVladi03 has much to be proud ofVladi03 has much to be proud ofVladi03 has much to be proud ofVladi03 has much to be proud of
pic: Team 399 BellyPan
Unread 09-02-2015, 23:44
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: pic: Team 399 BellyPan
It looks like you've wired your PCM into the VRM spot on the PDP, and vice versa. Other than that, looks great!
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 10-02-2015, 00:00
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
It doesn't matter which port they are plug into because the are both connected to the 20 amp fuse.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
Unread 10-02-2015, 00:04
Gregor's Avatar
R33 specifies that the VRM must be powered by the "designated supply terminals." While they should be the same thing, and the photo associated with R33 has all 4 connecters highlighted, the leftmost port (from the orientation of the photo) is specifically labelled on the PDP as for the VRM.
Rule is unclear, but it doesn't really hurt to change it because why not.
<Since 2011
Unread 10-02-2015, 00:10
I was about to comment on how CAN really makes for clean electrical layouts. Then I realized these are Victors, not Talons, and they have PWM cables. Well done!
Unread 10-02-2015, 12:01
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
I see the outlines of a swerve drive?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 10-02-2015, 22:30
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Very nice, very clean layout.
One suggestion - it looks, from the picture, that you have all of the pneumatics connected to the fitting on the compressor. You might consider moving them away and using a piece of tubing to connect the compressor to the pneumatics set.
In 2013, we had just a few components connected to that fitting and we cracked two of the compressor housings. That material is cast and is thin. We went through 3 compressors before we determined the cause was the stress on that part of the casting because that load will vibrate significantly while the compressor runs.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 13-02-2015, 15:34
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
This. There is a reason cymbals and bells are made of brass. Some brass on the compressor side is desirable for heat dissipation, but if there is a lot you should try to mitigate both the cantilevered loads, by using supports on the far end, and vibration, using dampers. Isolating a lot of that hardware by connecting it via rubber tubing would probably be the easiest.
