Go to Post I've been busier than a hog farmer at feedin' time. - Andy Baker [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 09-02-2015, 22:50
Joshua Sicz Joshua Sicz is offline
FRC #2403
Joshua Sicz is an unknown quantity at this point
What motors are you using for your lift?
Does anyone have any suggestions for what type of motor we could use for our lift? We found that bag motors are a little slow. We were trying to go with rs775's but having some trouble with the adapter. We only have 1 cim more allowed because we already used 5 on our drive.
And with that how did you guys hook up the motor? Planetary gear box? Simple box?
Just looking for some ideas.
I know of some team that is using a worm gear box so there is no drift.
Anyways thanks,
Joshua Sicz
Unread 09-02-2015, 23:10
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: What motors are you using for your lift?
A 775 in the 18v version does have enough power to lift 3 totes and a container. A Mini Cim also works. Personally I love the Versa Planetary for this sort of an application. The 775 motors interface with it very easily. You can interface the CIM or Mini CIM with it but you need to cut the shaft to assembly it per Vex recommendation. You also have a huge number of possible gear ratios with the Versa Planetary.
Unread 09-02-2015, 23:14
jagoldman jagoldman is offline
jagoldman
AKA: jagoldman
FRC #2972 (RC Dawson)
jagoldman is an unknown quantity at this point
My team is doing an elevator system that is run with chain. Our system is run by two Andymark 9015 motors and a 1:35 planetary from vex. These are the stats for the system are here.
Name:	Screen Shot 2015-02-09 at 9.08.46 PM.png
With what we have so far it seems to work fine, but if the 9015 motors are not strong enough we are going to switch to the bane bots RS-775-18 motors. Here are the stats for the RS-775-18 motors.
Name:	Screen Shot 2015-02-09 at 9.15.40 PM.png
My best advice would be to use the dual input attachment for the vex pro planetary gearbox. They are very easy to work with.
Best of luck!
PS. If you do use the 9015 motors, you have to cut the output shafts down a little for it to work with the dual input.
Unread 09-02-2015, 23:15
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
We're using 2 drive gearboxes with power take off, 2 CIMs per box. It's not quite enough to lift 3 totes, but we plan to gear it down more.
Unread 09-02-2015, 23:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Our tote lifter is powered by a CIM, through a toughbox, and chain sprocket reduction, which powers a cam, that lifts the arm. Kind of complicated sounding, but it works.
Our container lifter also uses a CIM and toughbox, and even more chain sprocket speed reduction, and it's also counterbalanced with a gas spring, and Latex tubing.
Springs of some sort can really help reduce the load on the motor, if you can figure out a way to use them. Our container lifter is balanced so that it needs to be driven down with a little bit of force when not holding a container, and driven up with about the same amount of force when it is holding a container. This cuts the load on the motor by quite a bit.
Unread 09-02-2015, 23:45
azcalg's Avatar
azcalg azcalg is offline
FRC #1212 (Sentinels)
azcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the rough
We're using a van door motor with a 3.5 in winch. It lifted all 6 totes and a recycling bin 6 feet in like 4 or 5 seconds with no problem. I think we might up the size of the winch to 5 in so it'll go a bit faster. Van door motor is probably the simplest solution for this game because it has tons of torque and it's fairly easy to implement (don't need a gearbox or anything).
Unread 09-02-2015, 23:52
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
We are using a Mini-CIM hooked up to a 30:1 versaplanitary gearbox. It lifts our whole 70inchs in about 4 seconds and can handle up to (theoretically) 300 lbs. (We ran some tests to see how much it could lift, but we broke the scale before the motor failed.) We also have no drift simply due to the ration we are using, it being to hard to turn without a substantial amount of force trying to back drive it.
Good luck!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 09-02-2015, 23:59
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Is this designed to create a reciprocating motion from the tote lifter while still only having to drive the motor forward? Sounds interesting/promising.
Unread 10-02-2015, 00:02
MrForbes's Avatar
AKA: Jim
Well...that would be nice, but it needs to reverse. We didn't come up with the cam design until a few days ago, and there's other stuff in the way of making it so it can go all the way around. The linkage system we're using on the container lifter will probably go all the way around in one direction.
Unread 10-02-2015, 00:03
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
We are using one RS775-18 through a drill motor planetary on the low speed.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 10-02-2015, 00:14
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
One cim on a toughbox. Lifts 6 totes at reasonable speed without a problem.
Head Programmer / Driver
Unread 10-02-2015, 00:18
Oblarg Oblarg is offline
AKA: Eli Barnett
Two AndyMark WormBoxes, each driven by a CIM. We didn't want to have to deal with a brake mechanism on our lift, so a worm drive was the obvious choice.
Overkill, but a little overkill never hurt anyone.
"The breakfast of champions!"
Unread 10-02-2015, 00:20
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Two CIMs, each on a Toughbox Nano. In testing today, looks to hold three totes and a container in place like a champ. Our grabber however... needs work.
Probably overkill, but it also gives us a nice counterweight to our lift.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 10-02-2015, 00:24
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
One CIM on a CIMple Box. It should work for what we need it to.
("Why?" You ask. "Because," I reply, "it's what we had on hand and purchase orders are a pain!")
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 10-02-2015, 00:25
FRC #2403
Good luck!
Is this with all 6 + bin?
