| Thread Tools |
Rating:
Display Modes |
#16
Re: What motors are you using for your lift?
Thanks, Joshua Sicz |
#17
Please remember thermal mass when/if you want to hold elevator position in PID loop with motor...the fan cooled motors are not a good choice for this.
-Ronnie |
#19
Using two versaplanetaries, each with a 50:1 ratio and a miniCIM. Definitely going to be enough, just not sure if it is fast enough. Might downsize later to like 30:1 or something similar.
#20
I can't find the specs at the moment, but I'm pretty sure the Taigene van door motors have quite a bit more torque than the window motors.
#21
Two CIMs geared 1.5:1 at the transmission. We can lift 6 plus container.
#22
One CIM, 1:25 versaplanetary gear box driving 15t sprocket chain system. Measured speed 1.3 feet per second. PID with 3 totes. Holding current about 8 amps using a clamp meter. About 25 amp at full speed with 3 totes. Our arm system is 22 pounds. No constant spring.
#23
Our lift mechanism originally used 2 CIMS one on each side through a 2 stage gearbox on each side. Due to weight issues, we swapped them out with 775 banebots with the CIMulator adaptor.
We saved 2 and 1/2 pounds and they easily lift the elevator with 6 totes with a trash can. When we had the CIMS on, there were overkill, but only decided to swap out due to weight issues. |
#24
We ended up using a cim for ours, geared 12:1 to the elevator via versaplanetary. We can switch to two if we need to or lower the gear ratio.
#25
Is there any good way to mount the VersaPlanetary Dual Motor Input? There are the two screw holes on the panetary gear box but I feel that would be too much weight only on two.
#26
Yes, the Taigene's stall torque is 360 lb-in and the window motor's (Denso) is 93.8 lb-in.
#27
Define what you mean by lift 6 totes plus 1 bin in 3-4 sec, how far do you want to lift it in that time? Once you have created a 6T + 1C stack you only need to lift it a little more than 2" to place it on the scoring platform. That should be able to be done in a fraction of a second. So how are you creating that stack, ie what is the heaviest load and how far to you need to lift it and what is the highest distance you need to lift and how much is that weight. Here is the JVN design calculator page. http://www.chiefdelphi.com/media/papers/2755? On the first tab copy the motor you wish to use and paste it into the linear motion tab motor fields. You can then select the motors per trans, gear box efficiency (I use 10% per planetary stage), the amount of weight you wish to lift (don't forget the weight of the mechanism and a fudge factor to overcome the friction), the distance you want to lift the load and then play with gear ratios. For the planetary it is easiest to put 1 in for the drive and the ratio of the stage in the driven fields. For stages you are not using just put 1 in both fields. It is a good idea to make sure that the stall torque is significantly more than the load you want to lift in case the load "sticks". Personally I wouldn't design for less than 2X the actual weight. Personally I'd recommend the Mini CIM or CIM for this application despite that it is more involved to mount. The 775 is a fan cooled motor so it doesn't like spinning slowly and really doesn't like being stalled. The CIM families on the other hand are much more tolerant of operating at slow speeds and being stalled. |
#28
We are using 2 snowblower motors direct driving opposite ends of a shaft with a pulley fixed in the center. It is essentially a winch. We only need to lift 2 totes max. at a time.
#29
FRC558 is running a custom 18:1 worm gearbox with dual mini CIM input and for now a 4" diameter drum.
#30
Two CIMs on the lift. Jumping on the six CIM hype train here.
