Go to Post Sally Ride says role models are needed - that's you. - JaneYoung [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 10-02-2015, 00:28
Joshua Sicz Joshua Sicz is offline
FRC #2403
Joshua Sicz is an unknown quantity at this point
Re: What motors are you using for your lift?
Originally Posted by jagoldman View Post
My team is doing an elevator system that is run with chain. Our system is run by two Andymark 9015 motors and a 1:35 planetary from vex. These are the stats for the system are here.
Attachment 18255
With what we have so far it seems to work fine, but if the 9015 motors are not strong enough we are going to switch to the bane bots RS-775-18 motors. Here are the stats for the RS-775-18 motors.
Attachment 18256
My best advice would be to use the dual input attachment for the vex pro planetary gearbox. They are very easy to work with.
Best of luck!
PS. If you do use the 9015 motors, you have to cut the output shafts down a little for it to work with the dual input.
Wow, thanks for all that info. It really came in handy. I really do like your suggestion. If we do the VersaPlanetary Dual Motor Input, with 2 rs775 - 18v what gear ratio would you suggest? 1 to3? We are looking to lift all 6 totes + bin in about 3 - 4 sec. Also do you know of the shipping time for banebot. That might be the right choice for us, to go through banebot. We just need the items this week.
Thanks,
Joshua Sicz
Unread 10-02-2015, 00:30
FRC #2403
Originally Posted by azcalg View Post
We're using a van door motor with a 3.5 in winch. It lifted all 6 totes and a recycling bin 6 feet in like 4 or 5 seconds with no problem. I think we might up the size of the winch to 5 in so it'll go a bit faster. Van door motor is probably the simplest solution for this game because it has tons of torque and it's fairly easy to implement (don't need a gearbox or anything).
Very interesting, we have tons of window motors in our shop. We might have to try it.
Unread 10-02-2015, 00:31
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Please remember thermal mass when/if you want to hold elevator position in PID loop with motor...the fan cooled motors are not a good choice for this.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 10-02-2015, 00:44
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Using two versaplanetaries, each with a 50:1 ratio and a miniCIM. Definitely going to be enough, just not sure if it is fast enough. Might downsize later to like 30:1 or something similar.
Unread 10-02-2015, 00:59
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
I can't find the specs at the moment, but I'm pretty sure the Taigene van door motors have quite a bit more torque than the window motors.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 10-02-2015, 01:04
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Two CIMs geared 1.5:1 at the transmission. We can lift 6 plus container.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 10-02-2015, 01:05
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
One CIM, 1:25 versaplanetary gear box driving 15t sprocket chain system. Measured speed 1.3 feet per second. PID with 3 totes. Holding current about 8 amps using a clamp meter. About 25 amp at full speed with 3 totes. Our arm system is 22 pounds. No constant spring.
Unread 10-02-2015, 01:32
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Our lift mechanism originally used 2 CIMS one on each side through a 2 stage gearbox on each side. Due to weight issues, we swapped them out with 775 banebots with the CIMulator adaptor.
We saved 2 and 1/2 pounds and they easily lift the elevator with 6 totes with a trash can.
When we had the CIMS on, there were overkill, but only decided to swap out due to weight issues.
Unread 10-02-2015, 01:37
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
We ended up using a cim for ours, geared 12:1 to the elevator via versaplanetary. We can switch to two if we need to or lower the gear ratio.
Unread 10-02-2015, 02:24
FRC #2403
Is there any good way to mount the VersaPlanetary Dual Motor Input? There are the two screw holes on the panetary gear box but I feel that would be too much weight only on two.
Thanks,
Joshua Sicz
Unread 10-02-2015, 02:52
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Yes, the Taigene's stall torque is 360 lb-in and the window motor's (Denso) is 93.8 lb-in.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 10-02-2015, 03:58
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Thanks,
Joshua Sicz
The gear ratio needed depends on what is happening after the transmission. What is the diameter of the drum or drive sprocket?
Define what you mean by lift 6 totes plus 1 bin in 3-4 sec, how far do you want to lift it in that time? Once you have created a 6T + 1C stack you only need to lift it a little more than 2" to place it on the scoring platform. That should be able to be done in a fraction of a second. So how are you creating that stack, ie what is the heaviest load and how far to you need to lift it and what is the highest distance you need to lift and how much is that weight.
Here is the JVN design calculator page. http://www.chiefdelphi.com/media/papers/2755? On the first tab copy the motor you wish to use and paste it into the linear motion tab motor fields.
You can then select the motors per trans, gear box efficiency (I use 10% per planetary stage), the amount of weight you wish to lift (don't forget the weight of the mechanism and a fudge factor to overcome the friction), the distance you want to lift the load and then play with gear ratios. For the planetary it is easiest to put 1 in for the drive and the ratio of the stage in the driven fields. For stages you are not using just put 1 in both fields. It is a good idea to make sure that the stall torque is significantly more than the load you want to lift in case the load "sticks". Personally I wouldn't design for less than 2X the actual weight.
Personally I'd recommend the Mini CIM or CIM for this application despite that it is more involved to mount. The 775 is a fan cooled motor so it doesn't like spinning slowly and really doesn't like being stalled. The CIM families on the other hand are much more tolerant of operating at slow speeds and being stalled.
Unread 10-02-2015, 05:49
BlueOps4216MrG's Avatar
BlueOps4216MrG BlueOps4216MrG is offline
Coach
FRC #4216 (Blue Ops)
BlueOps4216MrG is an unknown quantity at this point
We are using 2 snowblower motors direct driving opposite ends of a shaft with a pulley fixed in the center. It is essentially a winch. We only need to lift 2 totes max. at a time.
Unread 10-02-2015, 07:14
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC558 is running a custom 18:1 worm gearbox with dual mini CIM input and for now a 4" diameter drum.
Unread 10-02-2015, 07:30
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Two CIMs on the lift. Jumping on the six CIM hype train here.
