Go to Post We'll see how this goes... it could be fun. - Andy Baker [more]
Unread 10-02-2015, 02:37
Joshua Sicz Joshua Sicz is offline
FRC #2403
Joshua Sicz is an unknown quantity at this point
Lights on your robot
Lighting up our robot would be awesome this year but to get a perspective of what the community usually uses I would like to ask a couple of questions.
Where do you get your lights from? What are you using to control them? I was thinking a raspi.
We have dabbled a little in lights but never too much, but if it isn't that hard we would like to do some this year.
Unread 10-02-2015, 03:33
BenDSterling's Avatar
BenDSterling BenDSterling is offline
Alumni, Mentor, Volunteer
FRC #6325 (Reset Robotics)
BenDSterling will become famous soon enough
Re: Lights on your robot
We are using RGB light strips and an arduino to control them. It's basicly this. This year we are trying to sync our driver station lights and our robot lights.
Lead Mentor: FRC Team Reset Robotics (#6325)
Mentor: FTC Teams #9686 & #10396
Head of AV for Georgia FIRST Robotics
FTC South Super Regional planning committee member
Unread 10-02-2015, 07:05
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Although I don't know of we'll have the weight this year, but if we do I've ordered some adafruit neopixels. They are rgb individually addressable and have pre made arduino libraries. We will then use a few dio on our rev more board to communicate with an arduino what pre programed patterns we want to run. That's the plan anyways.
Unread 10-02-2015, 08:52
Team118Joseph's Avatar
Team118Joseph Team118Joseph is offline
The guy that did the lighting
AKA: Joseph Foster
FRC #0118 (Robonauts)
Team118Joseph will become famous soon enoughTeam118Joseph will become famous soon enough
We usually order the LPD-8806 strips from Adafruit. This year we are controling them using the RoboRio's SPI port.
FRC Countdown Website: http://frccountdown.hosthorde.net/
FRC Countdowns App: https://play.google.com/store/apps/d...h.frccountdown
Unread 10-02-2015, 09:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We use the KOP blinky light, it's orange, and we usually mount it so it's visible from the front of the robot. We also like the little blinky lights on the speed controllers, and there are some on the new RoboRio.
Unread 10-02-2015, 09:47
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We bought a 5m strip of RGB LEDs from sparkfun - non addressable. We're not using any of the relay ports this year for functional items, so we'll switch them using a couple of spikes. The next option would have been some DIO ports and smaller relay modules, followed by an external CPU (e.g. arduino) and relay modules.
Unread 10-02-2015, 10:08
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
We typically use one of the addressable strips from Adafruit, driven by an Arduino, taking messages from the robot software over I2C. Last year we used the NeoPixels, and while they were great, the timing required to drive them meant that interrupts were disabled on the Arduino, so we couldn't use I2C, and used digital I/O lines instead. Not ideal.
This year we are using the new DotStar strips from Adafruit. They are like the happy offspring of the LPD-8806 driver strip, and the NeoPixels. Nice and bright, no external driver chip for the LEDs, one more signal wire, but not as tight timing for signals, so you get interrupts back! So far we are really liking them.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 10-02-2015, 11:47
one_each one_each is offline
FRC #4057 (KB Bots)
one_each is an unknown quantity at this point
We are using Adafruit Neopixels being driven with a Teensy from PJRC. Communication is done through the USB port with the Teensy emulating a serial port. The display is used to communicate information to the drive team allowing them to keep their eyes on the robot. When the robot is disabled then the display shows the team number and scrolls messages.
Unread 10-02-2015, 12:06
homerun33ss's Avatar
homerun33ss homerun33ss is offline
AKA: James
FRC #3238 (Cyborg Ferrets)
Team Role: Electrical
homerun33ss is an unknown quantity at this point
Two good places to get LED strips and such are:
- SparkFun (as mentioned above) https://www.sparkfun.com/
- SuperBrightLEDs https://www.superbrightleds.com/
That's where we usually get ours. Also, Arduinos are a pretty solid and simple control option.
Unread 11-02-2015, 21:25
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I went the cheap route and ordered a led strip from amazon with a remote and power supply. After I cut the wire on the power supply and connected it to the vrm It was brought to my attention that ir receivers were illegal in match. So I cut the ir receiver and put pwm connections on each end. It works and is legal now but was a lot of work. It also only costs 25 dollars and being I personally payed for them it's worth it.
Unread 12-02-2015, 06:17
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
548 did nearly that on our shooter for Worlds and States.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 12-02-2015, 17:13
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Also if you would like to look at our code for the lights its here
