Go to Post In FIRST, success = inspiration. - Daniel Brim [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 10-02-2015, 03:58
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: What motors are you using for your lift?
Originally Posted by Joshua Sicz View Post
Wow, thanks for all that info. It really came in handy. I really do like your suggestion. If we do the VersaPlanetary Dual Motor Input, with 2 rs775 - 18v what gear ratio would you suggest? 1 to3? We are looking to lift all 6 totes + bin in about 3 - 4 sec. Also do you know of the shipping time for banebot. That might be the right choice for us, to go through banebot. We just need the items this week.
Thanks,
Joshua Sicz
The gear ratio needed depends on what is happening after the transmission. What is the diameter of the drum or drive sprocket?
Define what you mean by lift 6 totes plus 1 bin in 3-4 sec, how far do you want to lift it in that time? Once you have created a 6T + 1C stack you only need to lift it a little more than 2" to place it on the scoring platform. That should be able to be done in a fraction of a second. So how are you creating that stack, ie what is the heaviest load and how far to you need to lift it and what is the highest distance you need to lift and how much is that weight.
Here is the JVN design calculator page. http://www.chiefdelphi.com/media/papers/2755? On the first tab copy the motor you wish to use and paste it into the linear motion tab motor fields.
You can then select the motors per trans, gear box efficiency (I use 10% per planetary stage), the amount of weight you wish to lift (don't forget the weight of the mechanism and a fudge factor to overcome the friction), the distance you want to lift the load and then play with gear ratios. For the planetary it is easiest to put 1 in for the drive and the ratio of the stage in the driven fields. For stages you are not using just put 1 in both fields. It is a good idea to make sure that the stall torque is significantly more than the load you want to lift in case the load "sticks". Personally I wouldn't design for less than 2X the actual weight.
Personally I'd recommend the Mini CIM or CIM for this application despite that it is more involved to mount. The 775 is a fan cooled motor so it doesn't like spinning slowly and really doesn't like being stalled. The CIM families on the other hand are much more tolerant of operating at slow speeds and being stalled.
