Go to Post I got something totally different from my FIRST experience. to me the spirit of FIRST is all about sharing. during the 6 week build period, you share yourself with the other people on your team. at the competition, you share your creation with everyone who watches your 'bot play the game. - George1902 [more]
Unread 08-02-2015, 08:33
ShaneWong ShaneWong is offline
ShaneWong is an unknown quantity at this point
How to attach and code fsp 8268909?
Hi I'm from team 4732, I've been having trouble figuring out how to attach/program this button (http://www.repairclinic.com/PartDeta...8268909/830916). Any help you could offer would be greatly appreciated.
Unread 08-02-2015, 09:58
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: How to attach and code fsp 8268909?
Wire one side of the switch to ground and the other to a digital input channel.
On the programming side, look at the DigitalInput class:
http://team2168.org/javadoc/edu/wpi/...italInput.html
http://team2168.org
Unread 10-02-2015, 06:41
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
I was struggling for a long time trying to figure out how to program these to stop motors when pressed and if that's your plan check out this thread: http://www.chiefdelphi.com/forums/sh...=133983&page=4
Unread 10-02-2015, 11:13
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
It is hooked up to a PWM cable. You only need to wire the ground and signal (black and white, respectively) as the positive (red) wire has no use in a switch. Instead of plugging it into the PWM section of your RoboRIO, plug it into the section designated for digital inputs.
Programming side:
DigitalInput _switch1 = new DigitalInput(0);
if(_switch1.get) {
    System.out.println("Switch 1 is pressed!");
