Go to Post The robot is NOT a lie. - Rick TYler [more]
Unread 09-02-2015, 14:09
ranger719 ranger719 is offline
AKA: Matt Ho
FRC #4719 (Bulldogs)
ranger719 is an unknown quantity at this point
pic: Team 4719 Control Board
Unread 09-02-2015, 14:10
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: pic: Team 4719 Control Board
I don't see the main breaker switch.... It's nice and neat though!
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 09-02-2015, 14:29
Addison4300's Avatar
Addison4300 Addison4300 is offline
FRC is love, FRC is life
AKA: Addison
FRC #4300 (The Lion Kings)
Addison4300 is on a distinguished road
I love the organized wiring! Very neat and compact!
Unread 09-02-2015, 14:33
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
do you still need the DC/DC power regulator when you are using the VRM?
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 09-02-2015, 14:58
If you need more than 500ma at 5v, perhaps for an Axis ethernet camera, you will need something in addition to the main VRM. The old CPR-360 is a good choice, except that its output will start to droop when the battery voltage falls below about 7.5 volts.
Unread 09-02-2015, 15:24
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Looks sharp.
Your high pressure pneumatic circuit appears to be Y split to two regulators. R71 specifies that working pressure must be provided through one primary regulator.
If you want two different working pressures (say 60 psi and 30 psi), it is just a matter of hooking the regulators in series rather than parallel to satisfy the rule.
Also, what is the purpose of the manual valve just above the lower pressure gauge? It would seem to isolate the 'stored' and 'working' sides of the pneumatic system if closed. Inspectors may find issue with this due to R78. If this valve is ever closed, then opening the pressure vent plug would not relieve all stored pressure.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 10-02-2015, 00:53
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
Originally Posted by Jeffrafa View Post
Looks sharp.
Thanks for the info. We will correct both problems that you have indicated.
Unread 10-02-2015, 00:56
Ken Lam
FRC #4719
The dc voltage regulator on our board is for the camera.
Unread 10-02-2015, 00:57
Ken Lam
FRC #4719
The main breaker is on the chassis right next to our battery.
Unread 10-02-2015, 01:05
Vupa's Avatar
Vupa Vupa is offline
Mentor & Alumni
AKA: Alex Vu
FRC #4334 (Alberta Tech Alliance), FRC #6082 (Calgary Tech Coalition)
Vupa is on a distinguished road
Looking sharp 4719. We here at 4334 thoroughly believe in the painted black for superior performance.
Unread 10-02-2015, 01:19
AKA: Matt Ho
Thanks for all of the suggestions! We're fixing them ASAP
Unread 10-02-2015, 01:20
AKA: Matt Ho
Did you put racing stripes on though?!?
Unread 10-02-2015, 06:41
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
yara92 will become famous soon enoughyara92 will become famous soon enough
Can we use the older PD 2014, for training to by the new is expensive
TEAM 1946-Tamra
Unread 10-02-2015, 12:14
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
You can use the old PDB for practice/testing/prototyping all you want. You are required to use new PDP at competition per R25.
