Go to Post Just remember to never take the "Us vs Them" mentality and you should come out all right. - Ian Curtis [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 10-02-2015, 07:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: What motors are you using for your lift?
One CIM on an 8.45:1 gearbox (same as on the KOP for interchangeability), geared down 32:15 by chain, then lifting using two #35 chains on 15 tooth sprockets. It has several times the lifting power we'll need, because we're going to try it without a brake. We're only using three CIMs for drive, so we are going to check the current draw when we hold the maximum load (4 totes) and add another CIM if it's much over 20A, or if we experience too much heating during practice. On the curves it looks like it'll be about 14A, which means about 170W, all going to heat when holding station on four totes. I really suspect that we are going to build a brake on Thursday and Saturday.
  #32   Spotlight this post!
Unread 10-02-2015, 08:09
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Originally Posted by Oblarg View Post
Overkill, but a little overkill never hurt anyone.
An ironic choice of phrase
  #33   Spotlight this post!
Unread 10-02-2015, 09:17
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
We are using 1 mini-CIM connected to a 35:1 versaplanetary with a 15T sprocket driving a #35 chain to our elevator carriage. It seems to have the power and speed we were looking for.
  #34   Spotlight this post!
Unread 10-02-2015, 09:36
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
2 gearboxes, each with a CIM in a Banebots planetary with a 16:1 reduction. It lifts at a speed that satisfies us and can easily lift 6 totes and a container.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
  #35   Spotlight this post!
Unread 10-02-2015, 09:42
Knufire Knufire is offline
Two CIMs into a standard ratio AndyMark RAW Box on a 15T #35 sprocket (PD = 1.79").
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #36   Spotlight this post!
Unread 10-02-2015, 10:02
pfreivald's Avatar
AKA: Patrick Freivald
Two CIMs in a 12.75:1 toughbox.
We did the math on one CIM and decided we liked two better.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #37   Spotlight this post!
Unread 10-02-2015, 10:23
Thromgord's Avatar
Thromgord Thromgord is offline
The Warlord
FRC #3807 (The BlazerBots)
Team Role: Marketing
Thromgord has a spectacular aura aboutThromgord has a spectacular aura about
Our team is using a threaded rod setup.
We used two mini-CIMs on a Toughbox-Mini gearbox. It's more than enough for that particular purpose: we can lift six totes and a bin with no trouble.
  #38   Spotlight this post!
Unread 10-02-2015, 10:50
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
We are using a single Bag motor and some weight compensation trickery. It seems pretty unique compared to everyone else's specs, but it fits our strategy very well. We'll see.
  #39   Spotlight this post!
Unread 10-02-2015, 11:03
Originally Posted by GeeTwo View Post
On the curves it looks like it'll be about 14A, which means about 170W, all going to heat when holding...
14A @ 0 RPM is more like 18W.
  #40   Spotlight this post!
Unread 10-02-2015, 11:11
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
Originally Posted by Mr V View Post
The gear ratio needed depends on what is happening after the transmission. What is the diameter of the drum or drive sprocket?
Define what you mean by lift 6 totes plus 1 bin in 3-4 sec, how far do you want to lift it in that time? Once you have created a 6T + 1C stack you only need to lift it a little more than 2" to place it on the scoring platform. That should be able to be done in a fraction of a second. So how are you creating that stack, ie what is the heaviest load and how far to you need to lift it and what is the highest distance you need to lift and how much is that weight.
Here is the JVN design calculator page. http://www.chiefdelphi.com/media/papers/2755? On the first tab copy the motor you wish to use and paste it into the linear motion tab motor fields.
You can then select the motors per trans, gear box efficiency (I use 10% per planetary stage), the amount of weight you wish to lift (don't forget the weight of the mechanism and a fudge factor to overcome the friction), the distance you want to lift the load and then play with gear ratios. For the planetary it is easiest to put 1 in for the drive and the ratio of the stage in the driven fields. For stages you are not using just put 1 in both fields. It is a good idea to make sure that the stall torque is significantly more than the load you want to lift in case the load "sticks". Personally I wouldn't design for less than 2X the actual weight.
Personally I'd recommend the Mini CIM or CIM for this application despite that it is more involved to mount. The 775 is a fan cooled motor so it doesn't like spinning slowly and really doesn't like being stalled. The CIM families on the other hand are much more tolerant of operating at slow speeds and being stalled.
Agree!
We use a CIM motor last year for our winch and it performed well and tolerate stalling very well. The load we put on last year is way higher than this year's lift requirement. We did fried one CIM motor on our practice bot but that was only after practicing for 3 hours non stop. The motor was so hot we could fry an egg.
We use the JVN calculator to decide on the sprocket size and versaplanetary gear ratio for this year's lift. What we observe in real life is very close to what we predicted.
  #41   Spotlight this post!
Unread 10-02-2015, 11:44
Richard.Varone's Avatar
Richard.Varone Richard.Varone is offline
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
We're using 2 CIMs and a Mini-CIM with a 16.73:1 reduction
2016 FLR (Excellence in Engineering)
2015 NY (Regional Finalists) & LI (Quality Award)
2014 NY (Regional Finalists, Quality Award) & LI (Regional Finalists, Quality Award)
2011 LI (Regional Finalists, Innovation in Control)
2010 LI (Regional Champion, Engineering Excellence, Coopertition Award) & NY (Regional Finalist)
2009 LI (Innovation in Control) & NY (Creativity Award)
2008 LI (GM Industrial Design) & NY (Innovation in Control)
2007 LI (Delphi "Driving Tomorrow's Technology")
2006 LI (Regional Champion)
2005 LI (Regional Finalist)
2004 SC (Regional Finalist)
2003 LI (GM Industrial Design)
2002 CMP (Division Finalist - Newton)
2001 NY (Imagery)
  #42   Spotlight this post!
Unread 10-02-2015, 12:05
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Two RS775's, each powering a 50:1 Versaplanetary gearbox with a disc brake coupled inbetween the two gearboxes. A video of it can be found here: http://youtu.be/JrebWdH8x4c
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
  #43   Spotlight this post!
Unread 10-02-2015, 12:55
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
mini-CIM to 20:1 versaplanetary. seems to be as fast as we want and lifts fine. will be beginning PID testing in the next day or so to see how it handles the load. Hoping to not need a break.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
  #44   Spotlight this post!
Unread 10-02-2015, 13:10
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
I can't believe only one other person has mentioned BAG motors. In my opinion, they are the perfect choice for this application, as they have a similar free speed as the 775s and can interface perfectly with the VersaPlanetaries. Also, they aren't fan cooled and instead have a high thermal density, meaning they won't get wrecked as you PID loops try to hold the totes in place. They've been champs for us, and they weight only a fraction of a CIM or miniCIM.
  #45   Spotlight this post!
Unread 10-02-2015, 13:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The BAG motor might be ok for some lifts, but if there's a CIM or miniCIM available, why not overpower the mechanism? speed is good....power is good....extra capacity is good....
