Thread Tools |
Rating:
Display Modes |
Re: RS775 In Drivetrain?
When teams have burned out 775s, has it been because they were stalled or just under heavy load for long periods of time? Is a 775 designed for less continuous use than a minicim, or just not designed to be stalled?
We used them briefly last year. We had a 3 CIM Ball Shifter with 2 CIMs and an R775 on each side. We didn't see much performance boost and they became hot and didn't really work out well in our setup. This isn't to say they wouldn't work in your application but we just didn't see the need for them. As to the discussion about them burning out we never had that problem but i could see it happening if pushed continuously for very long periods of time.
I've heard of them being used in a gearbox that also has a CIM or two in it. Not sure how much benefit you get out of it though.
We are considering using them in place of minicims in our drivetrain, primarily to save weight.
That is not something I would recommend.
I specifically meant when paired with two other CIMs. But as others mentioned it does have some benefits that I was unaware of when in that configuration.
#7
The RS series motors need active cooling to keep the enamel on the commutator shaft from melting. This is achieved in stock form by an internal fan and air ducts at the front and rear of the housing. The RS series motors are intended for power tools and R/C cars where they have plenty of air movement and are typically driven in one direction for a continuous period of time (not fast forward-reverse motion like the FRC robot).
The CIMs and MiniCIMs have a higher thermal mass to dissipate the heat and typically use the gearbox as a heatsink. The large mating surface area helps conductive heat transfer and the overall larger system mass provides more heat capacity. During extended runs, you will likely notice the housing of both the gearbox and motor are warm, but not necessarily hot, unless there is high friction due to under/over-greasing of the transmission or improper assembly or other motor failure mode. I do not recommend using an RS motor for a critical, high load (high current) application such as the drivetrain. |
#8
Remember FP motors? Some teams used them in their drivetrains.
#9
If you do use the 775 in your drivetrain (or anywhere else) absolutely make sure it is well ventilated. If you use the CIM-Sim at least drill some holes in the plate where the motor mounts to allow air to enter the input vents. That said, the drivetrain is arguably the most important subsystem on your robot. Do a risk/reward analysis before moving from the miniCIM to the 775. Is there anyplace else you can save a few pounds? |
#10
As a team that has successfully used the 775 in numerous applications with no failures (arm motors in 2011, stalled to hold arm position; shooter motors in 2012; climbing motor in 2013; intake motors in 2014) ventilation in continuous-use applications is strongly recommended. Make sure you're operating in the higher-half of the RPM range too, they tend to heat up otherwise. IMO 775s would do fine in a drive-train that was driven at high speeds and would not do well in a drive-train that was mostly driven at low-throttle values. This is entirely based on the heating/efficiency of the motor - look at the motor curve and seriously consider where on that curve the motor will generally be operating. For this game, with lots of low-speeds and fine-positioning moves, it might not be a well-suited motor. Also bear in mind that drive-train weight is generally low in the robot. Removing mass from components higher off of the ground than the drive-train will have a larger positive impact on the robots overall dynamic performance. Last edited by JamesCH95 : 11-02-2015 at 09:28. |
#11
We haven't used them since that year. Fool me once, etc. Many other teams have used them since then. We used 550's very successfully on our drivetrain in 2008. That year, however, you were generally trying to drive at full speed. This year, there is a lot of slower-motion movement aligning, adjusting, and setting things down. That means that any low mass air-cooled motor is not going to be terribly happy. Active cooling on the motor (a fan) will help tremendously. |
#12
If you have a transmission without an air intake slot, it would be best to mill a slot for air intake. |
