Go to Post Reputation is a good thing to have. - adammiller3122 [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.33 average. Display Modes
Unread 10-02-2015, 14:15
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: WPILib C++ Deploy went away?
Huh, now that a more interesting issue than I though then... Are there any steps that can *reliably* do this on multiple machines? or is is very random?
Watchdog.Kill();
Unread 11-02-2015, 11:36
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
I can corroborate what JefferMC said; same thing here. I've also had deploy not work when I select it. The menu will close, Eclipse will freeze for a bit, then the console will briefly show up then close. This happens both when I'm connected to the robot's router and when I'm not connected to any network. I'm able to ping our roboRIO (10.35.12.2) when this happens. The contents contain the compiler commands invoked for the robot code but no deploy-related messages. Yesterday, it would even build random projects in the workspace instead of the robot code when I selected deploy.
I assume the code is deployed via the scp command, and if so, I definitely have a /usr/bin/scp. I'm running Arch Linux with the latest packages as of yesterday.
Edit: My team also has several Thinkpads running Debian Jessie on which the deploy command disappears.
Unread 11-02-2015, 11:40
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Brad Miller commented on this in another thread.
http://www.chiefdelphi.com/forums/sh...86&postcount=3
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 11-02-2015, 11:48
calcmogul's Avatar
WPILib Developer
AKA: Tyler Veness
The Java perspective thing doesn't seem to match my scenario. I never explicitly switch to the Java perspective, nor does the UI show being changed to that, when this bug occurs. Also, I just tried switching to the Java perspective and the C++ deploy option didn't disappear.
Unread 11-02-2015, 13:02
kylelanman's Avatar
Programming Mentor
AKA: Kyle
True...My point, not adequately stated, is that there is a bug related to switching perspectives in general that causes it to disappear.
Unread 12-02-2015, 17:14
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Yes, it most certainly happens when you switch perspectives. However, that's not the only thing that causes it. And it's a multi-platform problem, because I'm on a Windows 7 system.
