Go to Post The longer you play robots, the more you realize that it's not about the robots. - dtengineering [more]
Unread 10-02-2015, 14:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Lift cable
Originally Posted by Aur0r4 View Post
Another tip for spooling cable from the crane world is what we call "lagging". Basically, have your lathe team...
If you don't have a lathe, you could probably lag the spool with some epoxy and plastic wrap. Spread a relatively thin (about 1/4 the thickness of your cable) layer of epoxy around the core of the spool, wrap this in plastic wrap, then firmly wind the cable around the plastic wrap in a single layer to shape the epoxy. Remove the cable and (if you can) the plastic, and let the epoxy set. Note that I have not actually done this, so expect to have to experiment a bit.
Of course, I'd recommend an epoxy with a putty-like consistency that gives you at least 10 minutes to work with it.
Unread 10-02-2015, 19:13
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Re: Lift cable
Could get cable drum meant to go on to the end of a garage door torsion spring shaft. They are already "lagged" and probably a whole heck of a lot easier to acquire than create. A 4" diameter drum that will hold 8' of 1/8" cable is under $18/pair in a real quick search.
Nate
Unread 10-02-2015, 22:58
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Re: Lift cable
Every crane I've ever seen includes operating instructions to leave multiple turns of wire rope on the hoist drums...usually more than 3, sometimes as high as 9. This allows almost all of the force transfer to occur via friction and your mechanical connection doesn't see hardly any load.
Good luck!
I believe this is because of the Capstan effect:
http://en.wikipedia.org/wiki/Capstan_equation
