Go to Post Don't tell the rookies to "not touch the robot", show them how to work safely. - Andy Baker [more]
Unread 09-02-2015, 18:19
GIrobotics GIrobotics is offline
None #5498
GIrobotics is an unknown quantity at this point
Spray-on Rubber
Does spray on rubber or plastic count as a lubrication? We want to use the rubber or plastic as a barrier to prevent us from scratching the totes or trash can during the competition.
Unread 09-02-2015, 18:20
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Plastidip is an option
Unread 09-02-2015, 19:24
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Spray-on Rubber
Rubber? Probably not, considering it's quite likely the rubber will actually increase the "coefficient of grippy," and that's the precise opposite of what lubricants are supposed to do.
If I remember correctly, the main goal of that rule is likely to prevent grease and other oily or fluid lubricants from getting all over the field, so you're probably in the clear as far as both RAW and RAI. Still would Q&A if you aren't sure.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 09-02-2015, 23:30
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Spray-on Rubber
Spray on rubber certainly is not a lubricant once they are cured. I do not see anything in the rules that would make the use of them illegal.
Unread 10-02-2015, 14:21
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Spray-on Rubber
We sprayed a rubber coating on our kicker plate last year without issue.
Unread 10-02-2015, 14:25
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: Spray-on Rubber
your really all good unless it get super flakey on the field like plastidip can if done poorly
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
