Go to Post There's nothing that you can do to please everyone. You have to figure out where you stand and hold your ground. - sciguy125 [more]
Unread 09-02-2015, 20:05
DBaleta DBaleta is offline
FRC #2001
DBaleta is an unknown quantity at this point
Re: Compressor
Originally Posted by Mark McLeod View Post
If some of the LEDs next to the solenoid ports 0, 1, 2, 3 light but do not change, then there is still something wrong with the code.
Want to post the latest?
There are no LEDs next to the solenoid ports as far as I can tell.
Name:	SW AM Begin 2.png
ID:	18249  Click image for larger version
Name:	SW AM Telop 2.png
Unread 09-02-2015, 20:11
Re: Compressor
The PCM solenoid LEDs are easy to miss if they are off, and hard to miss if they are on. Here is what they look like:
If none of the LEDs are on then your commands are not getting to the PCM (or it's Disabled).
Did you go back with a web browser and confirm the CAN ID used by the PCM =0?
Unread 09-02-2015, 20:20
FRC #2001
Re: Compressor
The CAN ID is 0 and none of the LEDs are on. The Light Device LED box is unchecked. Could that be why?
Is there an example of how to program the buttons in Labview that I could see?
Unread 09-02-2015, 20:25
Re: Compressor
There are some examples here.
The Light Device LED is just a way to make the PCM flash so you can confirm which one it is if you have multiple PCMs.
You can test it by checking it then clicking Save. The PCM will immediately blink rapidly for a second or two.
Unread 10-02-2015, 15:57
FRC #2001
Re: Compressor
We reworked the programming and some LEDs do turn on. However only Solenoid B seems to work. Solenoid A automatically expands the piston and refuses to retract. Solenoid B (used for our noodle system) extends and retracts the piston correctly yet Solenoid A (used for our lift system) extends the piston without the pressing a button and refuses to retract.
Unread 10-02-2015, 16:13
Re: Compressor
Your Teleop code doesn't show where the Buttons array is coming from. It almost looks like there are two different arrays coming in from the top left, each being converted for some reason to a cluster, then a member of each cluster is being chosen independently to select the solenoid state.
Give us some more context so we can see what you're trying to control the solenoids with.
Unread 10-02-2015, 17:57
FRC #2001
Re: Compressor
The reason why we converted them to a cluster was because that was what we were used to the previous years. We changed them back into arrays.
Noodle Solenoid works (Previously labeled Solenoid B). Lift Solenoid doesn't (Previously labeled Solenoid A).
Name:	Telop 2-10-15.png
Unread 10-02-2015, 19:44
FRC #2001
Re: Compressor
We sorted everything out and now everything runs. Our team wants to reprogram the solenoids so that the pistons stop expanding or retracting once the button is let go. As of right now if you push a button, the piston will either fully extend or fully retract. No in between.
Unread 10-02-2015, 20:28
Re: Compressor
The two position pneumatic cylinders and solenoids only have two positions, no in-between.
There are some tricks possible, but success varies, e.g., two cylinders end to end can produce up to four different positions.
