Go to Post Oh yes - and thanks for giving us kids our dreams. - DonRotolo [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #46   Spotlight this post!
Unread 10-02-2015, 14:51
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: What motors are you using for your lift?
Posting what ratios you're using without also showing how big of a lever arm [pulley/sprocket/4-bar/etc] is involved is pretty meaningless.
  #47   Spotlight this post!
Unread 10-02-2015, 15:33
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Originally Posted by Joshua Sicz View Post
Is this with all 6 + bin?
We have had some issues with the chain driving the shaft skipping after it is loaded with 3+ totes, but that is a tensioning issue, not a problem with the motor. We have pulled over 100lbs of weight up with it (which is more than 6x7.6lbs (totes)+ 8.8x1 (bin)) We will be doing some actual testing with some totes once the tensioning is worked out and the chain no longer skips.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
  #48   Spotlight this post!
Unread 10-02-2015, 16:07
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
We have set up two opposing VexPro 2 speed ball shifting transmissions.
One has 2 CIM’s the other is only used as a shift on the fly ratcheting system.
It lined up so nicely putting the transmissions together..
Gear ratios of 8.33:1 and 3.6:1 on a custom 3d printed 1” diameter spool and strap guide system.
Per the JVN calculator, our low gear should move our 60” lift system fully in approximately 2 seconds with a 40lb. load and a stall load of 570lbs at 10amps. The high speed, which I doubt we will use much, runs the loaded lift at less than a second with a stall load of 250lbs at 19 amps.
It is “overkill” and so is the lift system that goes with it..
We will be adjusting speeds this week to fine tune the lift. Sure do not need to launch those totes into the stands..
Good luck to everyone this year!
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
  #49   Spotlight this post!
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
We used two CIMs with a vexpro single speed double reduction with the stock (slowest) speed. Then it goes from a 22 or 18t sprocket to a 72t sprocket. I am confident that mini CIMs would be plenty powerful if you don't have the motors to spare. This gives a ridiculous amount of torque so we can lift rather quickly compared to lifts that use smaller motors.
Edit: We don't use a spool, a continuous loop of chain lifts the arm things and that is driven off the shaft with the 72t with 22t sprockets.
  #50   Spotlight this post!
Unread 10-02-2015, 18:20
pfreivald's Avatar
AKA: Patrick Freivald
True enough. We're driving 2" diameter sprockets with our two 12:75:1 CIMs.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #51   Spotlight this post!
Unread 10-02-2015, 18:38
What are those sprockets driving?
  #52   Spotlight this post!
Unread 10-02-2015, 19:10
pfreivald's Avatar
A belt with more 2" sprockets along the way. The total moment arm on the toughbox output shaft is 1"--the rest of the pulleys are just for direction changes.
Team 1551
I write books, too!
  #53   Spotlight this post!
Unread 10-02-2015, 19:40
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
We are running a MiniCim with a Versa Planetary that is 36:1
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
  #54   Spotlight this post!
Unread 10-02-2015, 21:34
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
Robodox are using two old Bosch Van Door motors directly driving (via their included worm gearboxes) a 6" drum that has a few wraps of cord in a continuous loop lift.
- Mr. Van
  #55   Spotlight this post!
Unread 10-02-2015, 23:06
jagoldman jagoldman is offline
jagoldman
AKA: jagoldman
FRC #2972 (RC Dawson)
jagoldman is an unknown quantity at this point
I don't know the schedule that BaneBots works to, but its probably similar to that of vex or andymark. If you go onto VEX, they sell many different gear ratios for the planetary gearboxes. Since ours is a 1:35 ratio, we used a 1:5 stage and a 1:7 stage. A great resource is the JVN mechanical systems calculator. You can choose your own gear ratios and then make educated purchases. In the linear mechanisms category, you can specify the distance to travel and the weights for approximate times.
Best of luck!
  #56   Spotlight this post!
Unread 11-02-2015, 11:22
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
The Average Joes are using a can of spinach (aka CIM motor) on a RAW Box (AM-2372) with further reduction via Vexpro gears (30:84) to drive two 36 tooth Vexpro HTD pulleys on two 15mm wide belts, which connect to our left and right elevator carriages. Top unloaded speed is 4 seconds for a 60 inch lift, and we have lifted six totes while drawing 28 Amperes at the CIM terminals.
Richard Wallace
since 2003
  #57   Spotlight this post!
Unread 11-02-2015, 11:30
Professional Stat Padder
Originally Posted by MrForbes View Post
The BAG motor might be ok for some lifts, but if there's a CIM or miniCIM available, why not overpower the mechanism? speed is good....power is good....extra capacity is good....
Or you could attach 4 BAG motors with dual-input versaplanetaries and overpower your lift with less weight (for the same amount of power) than a similar solution using CIMs or MiniCIMs.
(2015-Present)
  #58   Spotlight this post!
Unread 11-02-2015, 11:32
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
we are using 2 cim's that run through 76 to 1 planetary gearboxes. They have been a pain to mount but we got it mounted yesterday. Now we just need to make the elevator plate and the bracket that connects it to the fork
