Go to Post Teach 'em young, and they will go far. - Vashts6583 [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 10-02-2015, 16:21
magnets's Avatar
magnets magnets is offline
Re: Blown talon srx modules
Originally Posted by GregGarner View Post
The 3.3V signal is not used by our encoder, and it is not terminated at the end of the cable. This effectively means that we have a 8 foot antenna on the 3.3V wire, which could pick up any signal in the area and connect it into the Talon 3.3V rail.
Finally we do intend to follow industry standard ESD protocol as part of the shotgun approach.
Interference is no longer an ESD problem.
Also, a wire that isn't terminated at one end isn't likely to result in much inductive coupling, and it will be much, much less than a wire that's terminated at both ends. Having it terminated at only one end will make inductive coupling almost disappear. There's no effective loop area if you don't have a loop!
You may have parasitic capacitive coupling though.
