Go to Post You think you are building robots, but you are really building yourselves. - sanddrag [more]
Unread 10-02-2015, 16:27
gwin99 gwin99 is offline
FRC #0751
gwin99 is infamous around these parts
Need help reducing shaft diameter
Hi, so my team recently found ourselves drastically overweight. To shave off pounds, we need to replace our steel shafts with aluminum. However, the aluminum rods we got (because McMaster Al shafts were $60 each) are 4-6 thousandths to big, and don't fit our linear bearings. The shafts are to long to turn down without wobbling, and we've tried hand sanding and belt sanding with no success. We've also tried turning it and using sandpaper, which seemed to work, but a less dangerous solution would be welcome.
Unread 10-02-2015, 16:35
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Re: Need help reducing shaft diameter
Are you saying that you guys were trying to turn down the whole shaft as it is COTS, or did you cut it into smaller lengths for their specific use on the robot, then turn them down? Does the shaft have to be that long because it's part of your design?
Unread 10-02-2015, 16:43
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
You can try loading the shaft into a hand drill chuck, spin the shaft while cupping the part with sand paper. Let the hand drill do the hard work. Go slow and keep checking the OD. also keep cleaning out the sand paper, your gonna get a lot of aluminum dust. It will take a while but its a low cost fix. I had to do this with a aluminum shafts a couple years ago. Make sure you got a fine grit sand paper too.
Also get in touch with 100 or 766 in your area. They should be able to help with this too.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 10-02-2015, 16:44
FRC #0751
We have 4 shafts that are 1/2in diameter and 38in long. They support the linear motion on our grabber. Changing them from steel to aluminum shaves off about 4 lbs, which is unfortunately necessary for us this year. The steel shafts we were using have a diameter of 0.498 in and the aluminum rods we want to replace them with are 0.504 in. The linear bearings don't slide on the aluminum rods, so we want to reduce the aluminum rods to the diameter of the steel shafts (.498 in), effectively shaving off 0.006 in consistently around / across the rod.
Even with a live center, and even if done 1/2 at a time, the shaft will wobble too much to use a normal cutting tool. Thus, we tried putting it in the lathe and running it while passing sandpaper along it. This was effective, but seems sketchy and dangerous. Any ideas on how to do this better / find cheaper Al shafts / do our sandpaper method more safely?
Unread 10-02-2015, 16:45
bEdhEd's Avatar
Whenever we use a drill and sand paper, we have someone hold it on the other side with a bearing. If the shaft is too big, try a bushing or a piece of pvc so you can hold on a little safer.
What seems sketchy to me actually is using linear bearings on an aluminum shaft that has been sanded or turned down. The aluminum may be too soft, and the surface of the sanded metal and possible bending of the shaft could cause binding.
This is not to discourage you, but it's just a precaution from what I speculate could happen. Ideally, linear bearings should ride on hardened steel. If this is what your team needs to get done, it may have to do. Have you lost all possible weight in other parts of the robot?
Unread 10-02-2015, 16:47
FRC #0751
It's to long to do in a hand drill, which is why we tried a similar method with the lathe. I accidentally got my thumb pinched between the paper and the shaft, which hurt a lot, so I was wondering if there's a safer / alternate way to do it.
Unread 10-02-2015, 16:52
Head Mentor
You lay the other end of the shaft in a v groove, I used a pile of plywood. You have to go very slow. I cupped the paper in my palm and held it firmly to the shaft but I was not trying to grab the shaft. Keep the paper loose start slow, then you apply more pressure. Slow down if you loosing the sand paper. Make sure its a very fine grit. I can't recall what I used.
Let me know if you need a contact for 766.
Unread 10-02-2015, 17:08
FRC #0751
Okay, thanks, I'll give that a shot today.
Unread 10-02-2015, 17:23
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
I suppose you cant use a Steady rest or follower rest in the lathe?
Unread 10-02-2015, 17:32
Head Mentor
I should add, when I did this I was not trying to go faster than a hand method but sustain that effort for a long time is tiresome, hence using the drill to make it easier. it will take a while, I think it me about a hour to fix 16 12 inch shafts. Slow and steady with this dirt cheap method.
This would work too. 100 or 766 should have these on their lathes if you don't have this.
