Go to Post With one post, Mr. Miller joins the top 0.7% of Chief Delphi, reputation-wise. I think the community supports him. - Taylor [more]
Unread 10-02-2015, 17:08
michaelyork michaelyork is offline
FRC #3680 (Elemental Dragons)
michaelyork is an unknown quantity at this point
Question Programming Mecanum Wheels
I have tried searching CD and WPILib for a while now, and tried everything. How do you do mecanum wheel programming?
Unread 10-02-2015, 18:19
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
Re: Programming Mecanum Wheels
Hi! I've dug up a few mechanum links from wpi located here: http://wpilib.screenstepslive.com/s/...botdrive-class and here: http://wpilib.screenstepslive.com/s/...-mecanum-drive.
I don't know if they particularly relate to your team's robot, but they will hopefully be useful! My team has done mechanum drivetrain for the two years I have been on the team, so let me know if you have any questions or need more explanation!
Unread 10-02-2015, 18:52
WPILib RobotDrive.java
     * Drive method for Mecanum wheeled robots.
     * A method for driving with Mecanum wheeled robots. There are 4 wheels
     * on the robot, arranged so that the front and back wheels are toed in 45 degrees.
     * When looking at the wheels from the top, the roller axles should form an X across the robot.
     * This is designed to be directly driven by joystick axes.
     * @param x The speed that the robot should drive in the X direction. [-1.0..1.0]
     * @param y The speed that the robot should drive in the Y direction.
     * This input is inverted to match the forward == -1.0 that joysticks produce. [-1.0..1.0]
     * @param rotation The rate of rotation for the robot that is completely independent of
     * the translation. [-1.0..1.0]
     * @param gyroAngle The current angle reading from the gyro.  Use this to implement field-oriented controls.
    public void mecanumDrive_Cartesian(double x, double y, double rotation, double gyroAngle) {
        if(!kMecanumCartesian_Reported) {
            UsageReporting.report(tResourceType.kResourceType_RobotDrive, getNumMotors(), tInstances.kRobotDrive_MecanumCartesian);
            kMecanumCartesian_Reported = true;
Unread 12-02-2015, 19:31
Question Re: Programming Mecanum Wheels
I have no idea why this code is not working, any ideas, I have been stressing about it for the past two hours.
        double magnitude = driveStick.getMagnitude();
        double direction = driveStick.getDirectionDegrees();
        double rotation = otherStick.getTwist();
        RobotDrive driveTrain = new RobotDrive(3,4,5,6);
        while (isEnabled() && isOperatorControl()) {
        	driveTrain.mecanumDrive_Polar(magnitude, direction, rotation);
        	Timer.delay(0.005);
This is located in teleopPeriodic() in Robot.java.
Any ideas?
Unread 12-02-2015, 22:43
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
cstelter will become famous soon enough
You probably want to fetch the current values from your joystick *inside* the while(isEnabled && isOperatorControl()) loop. Otherwise you take the reading once and keep sending them over and over.
